EnvisaLink Ademco Plug-in - Beta Testing
This is a sticky topic.
  • #91
    Originally posted by Ltek View Post
    I've tried updating the .26 5 times... even rebooted Homeseer. "Install/Update of package EnvisaLinkAdemco failed."
    Log
    Installation of package EnvisaLinkAdemco failed. The installation file 'EnvisaLinkAdemco_3-0-0-25.zip' does not exist. Please retry download.
    Finally figured out inside override file zip name is wrong. ... easy miss, no biggie except that the way HS installs out-of-band plugins is pure amateur hour! If they'd do it right it would be nearly mistake proof. Arg
    sorry for that, it's fixed now.
    • #92
      No biggie, super easy to do... Not your fault the update method is bad
      Sent from my SAMSUNG-SM-G935A using Tapatalk
      • #93
        Hi Spud,
        Saw there is an update from .27 to .29 but did not see release notes. What changed and do we need to test it?
        Michael
        • #94
          Originally posted by Jobee View Post
          Hi Spud,
          Michael
          I have updated the release notes in first post of this thread
          • #95
            I downloaded plugin version 3.0.0.30 but I still see some zones flipping between opened and closed when they are open -- Zone 1 and Zone 4 are sitting there open but it appears that there may be some timer to decide the zone is closed if no panel fault message has appeared within a certain time period? This is a Vista 128BP with EnvisaLink TYPE: EVL4 HW Version: 130
            Apr-06 4:09:52 PM EnvisaLinkAdemco INFO Zone 1 status change: Opened
            Apr-06 4:09:47 PM EnvisaLinkAdemco INFO Zone 1 status change: Closed
            Apr-06 4:08:52 PM EnvisaLinkAdemco INFO Zone 4 status change: Opened
            Apr-06 4:08:47 PM EnvisaLinkAdemco INFO Zone 4 status change: Closed
            Apr-06 4:08:42 PM EnvisaLinkAdemco INFO Zone 1 status change: Opened
            Apr-06 4:08:37 PM EnvisaLinkAdemco INFO Zone 1 status change: Closed
            Apr-06 4:07:07 PM EnvisaLinkAdemco INFO Zone 4 status change: Opened
            Apr-06 4:07:02 PM EnvisaLinkAdemco INFO Zone 1 status change: Opened
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 48 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 47 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 46 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 45 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 44 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 43 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 42 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 41 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 40 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 39 status change: Closed
            Apr-06 4:06:57 PM EnvisaLinkAdemco INFO Zone 38 status change: Closed
            • #96
              Could you try to capture a debug log of the problem? Thanks
              • #97
                Yes, will do it later today
                Sent from my SM-N950U using Tapatalk
                • #98
                  Here is a log from both the HomeSeer log and the Log to File option on the plugin -- with debug logging enabled...
                  • #99
                    Edit Config/EnvisaLinkAdemco.ini, and add the following line in the [PANEL] section:
                    [PANEL]
                    keypad_update_interval=10
                    then restart the EnvisaLinkAdemco plugin
                    the default value for this parameter is 5, increasing it to 10 should solve your problem. If the problem persists try to increase it more.
                    • Thanks! It has been running several hours now with the parameter at 10 and I've seen no duplicate messages. Ordinarily I would have seen hundreds by now so this fixed the problem.
