does this plugin only work on a windows system or will it work with the linux version of homeseer. HS3 / HS2 Pro
compatability
Originally posted by sk74991will it work with a hometoller Zee?
if you reinstall the full version of HS3 linux on your Zee then it should work.
Just an FYI. The reason the Zee is limited to a select few plugins is the Zee doesn't have the resources (mostly RAM) to run several plugins at once. The SEL is a better option if this is what you want to accomplish. See this comparison list of the available controllers.
http://homeseer.com/compare-controllers.html
