Help with Trigger for Event - open door when alarm set
  • Help with Trigger for Event - open door when alarm set
    I have a trigger to turn on the kitchen lights when the back door opens if they are not already on between dark and sunrise. I thought I was going crazy as it was only working sometimes. Tonight I figured it out but need help.
    The event works but only if the alarm is off. If the alarm is set (stay or away) and you open the back door, the door open is never logged. I repeated it several times.
    Here is the log when the alarm is off and the event works:
    May-14 20:26:18 EnvisaLinkAdemco DEBUG CommandAck 02,00
    May-14 20:26:18 EnvisaLinkAdemco DEBUG Received: ^02,00$
    May-14 20:26:17 EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
    May-14 20:26:15 Z-Wave Device: 1 Kitchen KitchenCans02 Set to 255
    May-14 20:26:15 Z-Wave Z-NET-FLOOR1: Sending to node 5 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
    May-14 20:26:15 Z-Wave Device: 1 Kitchen KitchenCans01 Set to 255
    May-14 20:26:15 Z-Wave Z-NET-FLOOR1: Sending to node 4 (UnSecured) CC=COMMAND_CLASS_SWITCH_BINARY
    May-14 20:26:15 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0028,02,03,FAULT 02 BACK DOOR
    May-14 20:26:15 EnvisaLinkAdemco INFO Z02 Back Doors status change: Opened
    May-14 20:26:15 Device Control Device: 1 Kitchen KitchenCans02 to On (255)
    May-14 20:26:15 Device Control Device: 1 Kitchen KitchenCans01 to On (255)
    May-14 20:26:15 Event Event Trigger "Kitchen Lights Kitchen Lights On (If Off) When Back Door Opens At Night"
    May-14 20:26:15 EnvisaLinkAdemco DEBUG ZoneStateChange 82000000000000000000000000000000
    May-14 20:26:15 EnvisaLinkAdemco DEBUG PartitionStateChange 0300000000000000
    May-14 20:26:15 EnvisaLinkAdemco DEBUG Received: %02,0300000000000000$ %01,82000000000000000000000000000000$ %00,01,0028,02,03,FAULT 02 BACK DOOR $
    Here is the log when the alarm is set and the back door opens:
    May-14 20:36:54 EnvisaLinkAdemco DEBUG CommandAck 02,00
    May-14 20:36:54 EnvisaLinkAdemco DEBUG Received: ^02,00$
    May-14 20:36:53 EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
    May-14 20:36:50 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,1C28,08,01, DISARMED CHIME Ready to Arm
    May-14 20:36:50 EnvisaLinkAdemco DEBUG PartitionStateChange 0100000000000000
    May-14 20:36:50 EnvisaLinkAdemco DEBUG Received: %02,0100000000000000$ %00,01,1C28,08,01, DISARMED CHIME Ready to Arm $
    May-14 20:36:49 EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 1CEE80FF0000000000002BFC0FFCE9FF0000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
    May-14 20:36:49 EnvisaLinkAdemco DEBUG Received: %FF,1CEE80FF0000000000002BFC0FFCE9FF000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
    May-14 20:36:48 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,05,DISARM SYSTEM or alarm occurs
    May-14 20:36:48 EnvisaLinkAdemco DEBUG CommandAck 02,00
    May-14 20:36:48 EnvisaLinkAdemco DEBUG Received: ^02,00$ %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $
    May-14 20:36:48 EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
    May-14 20:36:47 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,05,DISARM SYSTEM or alarm occurs
    May-14 20:36:47 EnvisaLinkAdemco DEBUG Received: %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $
    May-14 20:36:46 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,05,DISARM SYSTEM or alarm occurs
    May-14 20:36:46 EnvisaLinkAdemco DEBUG Received: %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $
    May-14 20:36:44 EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 1DEE81FF0000000000002CFC10FCEAFF0000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
    May-14 20:36:44 EnvisaLinkAdemco DEBUG Received: %FF,1DEE81FF0000000000002CFC10FCEAFF000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
    May-14 20:36:43 EnvisaLinkAdemco DEBUG CommandAck 02,00
    May-14 20:36:43 EnvisaLinkAdemco DEBUG Received: ^02,00$
    May-14 20:36:43 EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
    May-14 20:36:42 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,05,DISARM SYSTEM or alarm occurs
    May-14 20:36:42 EnvisaLinkAdemco DEBUG Received: %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $
    May-14 20:36:40 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,05,DISARM SYSTEM or alarm occurs
    May-14 20:36:40 EnvisaLinkAdemco DEBUG Received: %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $
    May-14 20:36:39 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,05,DISARM SYSTEM or alarm occurs
    May-14 20:36:39 EnvisaLinkAdemco DEBUG PartitionStateChange 0700000000000000
    May-14 20:36:39 EnvisaLinkAdemco DEBUG Received: %02,0700000000000000$ %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $
    May-14 20:36:39 EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 1EEE82FF0000000000002DFC11FCEBFF0000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
    May-14 20:36:39 EnvisaLinkAdemco DEBUG Received: %FF,1EEE82FF0000000000002DFC11FCEBFF000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
    May-14 20:36:38 EnvisaLinkAdemco DEBUG CommandAck 02,00
    May-14 20:36:38 EnvisaLinkAdemco DEBUG Received: ^02,00$
    May-14 20:36:38 EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
    May-14 20:36:37 EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,8C28,08,00,ARMED ***STAY***
    May-14 20:36:37 EnvisaLinkAdemco DEBUG Received: %00,01,8C28,08,00,ARMED ***STAY*** $
    So when the alarm is set and you open the door, it goes to DISARM SYSTEM or ALARM OCCURS but never shows what triggered the count down.
    Is this the board not sending out or are you missing the change when it happens?
    HS3Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
    This is a known limitation of Ademco panels: zone changes are not reported when security system is armed.
      Thanks.
      Since they are sending:
      What can I use. Looked at all the items in the list. Do I need to do something with the string value in the root or partition?
      Any suggestions, would be great.
      Update: I got it. I did a new event looking at Partition 1 and value of 7 (Exit Delay In Progress)
      HS3Pro on Win2012R2
        there is actually 2 messages here
        %02,0700000000000000$ is a "Partition State Change" message and means partition 1 state has changed to "Exit Delay in Progress". The partition 1 device is updated accordingly.
        %00,01,8C28,08,05,DISARM SYSTEM or alarm occurs $ is a "Virtual Keypad Update", after this message the root device string is updated to "DISARM SYSTEM or alarm occurs"
        If you want to trigger an Event based on the root's string change you will need something like the EasyTrigger plugin which allow to use triggers based on strings
