Entry Exit points showing double in log and trigger events
  • Entry Exit points showing double in log and trigger events
    Hi Spud,
    I am trying to track down a problem and starting with your side. I have 2 zones that are entry exit points. They are setup correctly in the panel and envisalink is sending them to HS3 plugin ok, but I seem to be getting double entry.
    If I open the back door and then shut it, I get the open and close with the correct number of seconds inbetween based on how long I had the door open. But then a few seconds later, I get a second set of open and close without opening the door.
    So in the below I opened the back ddor at 14:25:06 for 23 seconds. Then I got a second Open/Close 22 seconds later for 4 seconds. The door was not opened for this action. This is happening on both my front door and back door. The weird part is that it does not happen every time. It seems to happen when the open/close are at the beginning of a minute and there is time for a second set to happen before the minute is up.
    Nov-08 14:25:55 EnvisaLinkAdemco INFO Z02 Back Doors status change: Closed
    Nov-08 14:25:51 EnvisaLinkAdemco INFO Z02 Back Doors status change: Opened
    Nov-08 14:25:29 EnvisaLinkAdemco INFO Z02 Back Doors status change: Closed
    Nov-08 14:25:06 EnvisaLinkAdemco INFO Z02 Back Doors status change: Opened
    Let me know if you need logs or more information. Maybe it is a known issue? Are others seeing the same thing?
    Normally I would not mind, but I trigger an event off of this and it is causing issues when there is a double entry.
    Michael
    HS3Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
    I would need to see a debug log of the problem
    thanks
      Debug attached.
      Happened at 15:55. I opened the front door at 15:55:10 and closed the door at 15:55:34. I continued walking in the house and did not open the door at 15:55:43 with a close at 15:55:44. I did open the back door at 15:55:52.
      Nov-09 15:55:54 EnvisaLinkAdemco INFO Z07 Living Room Motion status change: Closed
      Nov-09 15:55:54 EnvisaLinkAdemco INFO Z03 Front Door status change: Closed
      Nov-09 15:55:52 Event Event Trigger "Announcements Greeting when Back Door Opens"
      Nov-09 15:55:52 EnvisaLinkAdemco INFO Z07 Living Room Motion status change: Opened
      Nov-09 15:55:52 EnvisaLinkAdemco INFO Z03 Front Door status change: Opened
      Nov-09 15:55:52 EnvisaLinkAdemco INFO Z02 Back Doors status change: Opened
      Nov-09 15:55:49 EnvisaLinkAdemco INFO Z07 Living Room Motion status change: Closed
      Nov-09 15:55:48 TTS Speak: (SPEAKEFAULT):Good afternoon. It is currently 3:55 PM and 73.5 degrees.
      Nov-09 15:55:44 EnvisaLinkAdemco INFO Z03 Front Door status change: Closed
      Nov-09 15:55:43 Event Event Trigger "Announcements Greeting when Front Door Opens"
      Nov-09 15:55:43 EnvisaLinkAdemco INFO Z03 Front Door status change: Opened
      Nov-09 15:55:34 EnvisaLinkAdemco INFO Z03 Front Door status change: Closed
      Nov-09 15:55:19 EnvisaLinkAdemco INFO Z07 Living Room Motion status change: Opened
      Nov-09 15:55:15 TTS Speak: (SPEAKEFAULT):Good afternoon. It is currently 3:55 PM and 73.5 degrees.
      Nov-09 15:55:10 Event Event Trigger "Announcements Greeting when Front Door Opens"
      Nov-09 15:55:10 EnvisaLinkAdemco INFO Z03 Front Door status change: Opened
      HS3Pro on Win2012R2
        the envisalink board does not report to the plugin when a zone is closed, so the plugin uses a complex logic based on timers to infer this information, this can become very tricky when several zones are opened in a short period of time, and leads to bugs like this.
        one workaround is to edit EnvisaLinkAdemco.ini, and add the following parameter in the PANEL section
        [PANEL]
        keypad_update_interval = 30
        The default value is 5, making it 30 should fix your problem, but it will increase the delay before the plugin considers a zone closed, i.e you close the door now but the corresponding HS device has its status changed to Closed only 1 minute later.
          Thanks.
          The change did help.
          Michael
          HS3Pro on Win2012R2
            I'm having what appears to be the same issue. What ended up resolving this? I've tried making keypad_update_interval = 30 but I still have issues?
              I think your issue has a different cause, I answered you in the other thread: https://forums.homeseer.com/showthre...61#post1352961
                Better with update but...
                The updated plugin has helped but it's still triggers a duplicate sometimes.
                Here's my debug log
                Mar-14 11:54:02 DEBUG EnvisaLinkZoneTimerDump 00000000E7FFF7FF0000C7FF603EB2F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:04 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:54:04 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:05 DEBUG Received: %02,0300000000000000$
                %00,01,0028,04,00,FAULT 04 $
                Mar-14 11:54:05 DEBUG PartitionStateChange 0300000000000000
                Mar-14 11:54:05 INFO Partition 1 status change: Not ready
                Mar-14 11:54:05 DEBUG VirtualKeypadUpdate 01,0028,04,00,FAULT 04
                Mar-14 11:54:07 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:07 DEBUG Received: ^02,00$
                Mar-14 11:54:07 DEBUG CommandAck 02,00
                Mar-14 11:54:07 DEBUG Received: %FF,00000000E6FFFEFF0000C6FF5F3EB1F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:07 DEBUG EnvisaLinkZoneTimerDump 00000000E6FFFEFF0000C6FF5F3EB1F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:07 INFO Basement Motion status change: Opened
                Mar-14 11:54:09 DEBUG Received: %00,01,0028,04,00,FAULT 04 $
                Mar-14 11:54:09 DEBUG VirtualKeypadUpdate 01,0028,04,00,FAULT 04
                Mar-14 11:54:12 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:12 DEBUG Received: ^02,00$
                Mar-14 11:54:12 DEBUG CommandAck 02,00
                Mar-14 11:54:12 DEBUG Received: %FF,00000000E5FFFEFF0000C5FF5E3EB0F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:12 DEBUG EnvisaLinkZoneTimerDump 00000000E5FFFEFF0000C5FF5E3EB0F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:13 DEBUG Received: %02,0100000000000000$
                Mar-14 11:54:13 DEBUG PartitionStateChange 0100000000000000
                Mar-14 11:54:13 INFO Partition 1 status change: Ready
                Mar-14 11:54:13 INFO Basement Motion status change: Closed
                Mar-14 11:54:13 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:16 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:54:16 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:17 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:17 DEBUG Received: ^02,00$
                Mar-14 11:54:17 DEBUG CommandAck 02,00
                Mar-14 11:54:17 DEBUG Received: %FF,00000000E4FFFDFF0000C4FF5D3EAFF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:17 DEBUG EnvisaLinkZoneTimerDump 00000000E4FFFDFF0000C4FF5D3EAFF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:17 DEBUG Cannot set zone status to open if partition is Ready
                Mar-14 11:54:22 DEBUG Received: %02,0300000000000000$
                %01,28000000000000000000000000000000$
                %00,01,0028,06,03,FAULT 06 $
                Mar-14 11:54:22 DEBUG PartitionStateChange 0300000000000000
                Mar-14 11:54:22 INFO Partition 1 status change: Not ready
                Mar-14 11:54:22 DEBUG ZoneStateChange 28000000000000000000000000000000
                Mar-14 11:54:22 INFO Basement Motion status change: Opened
                Mar-14 11:54:22 INFO Back Door status change: Opened
                Mar-14 11:54:22 DEBUG VirtualKeypadUpdate 01,0028,06,03,FAULT 06
                Mar-14 11:54:22 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:22 DEBUG Received: ^02,00$
                Mar-14 11:54:22 DEBUG CommandAck 02,00
                Mar-14 11:54:22 DEBUG Received: %FF,00000000E3FFFCFF0000FEFF5C3EAEF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:22 DEBUG EnvisaLinkZoneTimerDump 00000000E3FFFCFF0000FEFF5C3EAEF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:25 DEBUG Received: %02,0100000000000000$
                Mar-14 11:54:25 DEBUG PartitionStateChange 0100000000000000
                Mar-14 11:54:25 INFO Partition 1 status change: Ready
                Mar-14 11:54:25 INFO Basement Motion status change: Closed
                Mar-14 11:54:25 INFO Back Door status change: Closed
                Mar-14 11:54:25 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:27 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:27 DEBUG Received: ^02,00$
                Mar-14 11:54:27 DEBUG CommandAck 02,00
                Mar-14 11:54:27 DEBUG Received: %FF,00000000E2FFFBFF0000FDFF5B3EADF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:27 DEBUG EnvisaLinkZoneTimerDump 00000000E2FFFBFF0000FDFF5B3EADF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:27 DEBUG Cannot set zone status to open if partition is Ready
                Mar-14 11:54:29 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:54:29 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:32 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:32 DEBUG Received: ^02,00$
                Mar-14 11:54:32 DEBUG CommandAck 02,00
                Mar-14 11:54:32 DEBUG Received: %FF,00000000E1FFFAFF0000FCFF5A3EACF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:32 DEBUG EnvisaLinkZoneTimerDump 00000000E1FFFAFF0000FCFF5A3EACF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:33 DEBUG Received: %02,0300000000000000$
                %01,2C000000000000000000000000000000$
                %00,01,0028,03,00,FAULT 03 $
                Mar-14 11:54:33 DEBUG PartitionStateChange 0300000000000000
                Mar-14 11:54:33 INFO Partition 1 status change: Not ready
                Mar-14 11:54:33 DEBUG ZoneStateChange 2C000000000000000000000000000000
                Mar-14 11:54:33 INFO Foyer Motion status change: Opened
                Mar-14 11:54:33 INFO Basement Motion status change: Opened
                Mar-14 11:54:33 INFO Back Door status change: Opened
                Mar-14 11:54:33 DEBUG VirtualKeypadUpdate 01,0028,03,00,FAULT 03
                Mar-14 11:54:36 DEBUG Received: %00,01,0028,03,00,FAULT 03 $
                Mar-14 11:54:36 DEBUG VirtualKeypadUpdate 01,0028,03,00,FAULT 03
                Mar-14 11:54:37 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:37 DEBUG Received: ^02,00$
                Mar-14 11:54:37 DEBUG CommandAck 02,00
                Mar-14 11:54:37 DEBUG Received: %FF,00000000FEFFF9FF0000FBFF593EABF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:37 DEBUG EnvisaLinkZoneTimerDump 00000000FEFFF9FF0000FBFF593EABF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:37 INFO Basement Motion status change: Closed
                Mar-14 11:54:40 DEBUG Received: %02,0100000000000000$
                Mar-14 11:54:40 DEBUG PartitionStateChange 0100000000000000
                Mar-14 11:54:40 INFO Partition 1 status change: Ready
                Mar-14 11:54:40 INFO Foyer Motion status change: Closed
                Mar-14 11:54:40 INFO Back Door status change: Closed
                Mar-14 11:54:40 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:42 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:42 DEBUG Received: ^02,00$
                Mar-14 11:54:42 DEBUG CommandAck 02,00
                Mar-14 11:54:42 DEBUG Received: %FF,00000000FDFFF8FF0000FAFF583EAAF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:42 DEBUG EnvisaLinkZoneTimerDump 00000000FDFFF8FF0000FAFF583EAAF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:42 DEBUG Cannot set zone status to open if partition is Ready
                Mar-14 11:54:43 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:54:43 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:46 DEBUG Received: %02,0300000000000000$
                Mar-14 11:54:46 DEBUG PartitionStateChange 0300000000000000
                Mar-14 11:54:46 INFO Partition 1 status change: Not ready
                Mar-14 11:54:46 DEBUG VirtualKeypadUpdate 01,0028,03,00,FAULT 03
                Mar-14 11:54:47 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:47 DEBUG Received: ^02,00$
                Mar-14 11:54:47 DEBUG CommandAck 02,00
                Mar-14 11:54:47 DEBUG Received: %FF,00000000FEFFF7FF0000F9FF573EA9F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:47 DEBUG EnvisaLinkZoneTimerDump 00000000FEFFF7FF0000F9FF573EA9F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:47 INFO Foyer Motion status change: Opened
                Mar-14 11:54:50 DEBUG Received: %00,01,0028,03,00,FAULT 03 $
                Mar-14 11:54:50 DEBUG VirtualKeypadUpdate 01,0028,03,00,FAULT 03
                Mar-14 11:54:52 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:52 DEBUG Received: ^02,00$
                Mar-14 11:54:52 DEBUG CommandAck 02,00
                Mar-14 11:54:52 DEBUG Received: %FF,00000000FEFFF6FF0000F8FF563EA8F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:52 DEBUG EnvisaLinkZoneTimerDump 00000000FEFFF6FF0000F8FF563EA8F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:54 DEBUG Received: %02,0100000000000000$
                Mar-14 11:54:54 DEBUG PartitionStateChange 0100000000000000
                Mar-14 11:54:54 INFO Partition 1 status change: Ready
                Mar-14 11:54:54 INFO Foyer Motion status change: Closed
                Mar-14 11:54:54 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:54:57 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:54:57 DEBUG Received: ^02,00$
                Mar-14 11:54:57 DEBUG CommandAck 02,00
                Mar-14 11:54:57 DEBUG Received: %FF,00000000FDFFF5FF0000F7FF553EA7F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:54:57 DEBUG EnvisaLinkZoneTimerDump 00000000FDFFF5FF0000F7FF553EA7F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:54:57 DEBUG Cannot set zone status to open if partition is Ready
                Mar-14 11:54:57 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:54:57 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:55:02 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:02 DEBUG Received: ^02,00$
                Mar-14 11:55:02 DEBUG CommandAck 02,00
                Mar-14 11:55:02 DEBUG Received: %FF,00000000FCFFF4FF0000F6FF543EA6F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:02 DEBUG EnvisaLinkZoneTimerDump 00000000FCFFF4FF0000F6FF543EA6F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:07 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:07 DEBUG Received: ^02,00$
                Mar-14 11:55:07 DEBUG CommandAck 02,00
                Mar-14 11:55:07 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:55:07 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:55:07 DEBUG Received: %FF,00000000FBFFF3FF0000F5FF533EA5F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:07 DEBUG EnvisaLinkZoneTimerDump 00000000FBFFF3FF0000F5FF533EA5F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:12 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:12 DEBUG Received: ^02,00$
                Mar-14 11:55:12 DEBUG CommandAck 02,00
                Mar-14 11:55:12 DEBUG Received: %FF,00000000FAFFF2FF0000F4FF523EA4F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:12 DEBUG EnvisaLinkZoneTimerDump 00000000FAFFF2FF0000F4FF523EA4F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:17 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:55:17 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:55:17 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:17 DEBUG Received: ^02,00$
                Mar-14 11:55:17 DEBUG CommandAck 02,00
                Mar-14 11:55:17 DEBUG Received: %FF,00000000F9FFF1FF0000F3FF513EA3F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:17 DEBUG EnvisaLinkZoneTimerDump 00000000F9FFF1FF0000F3FF513EA3F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:22 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:22 DEBUG Received: ^02,00$
                Mar-14 11:55:22 DEBUG CommandAck 02,00
                Mar-14 11:55:22 DEBUG Received: %FF,00000000F8FFF0FF0000F2FF503EA2F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:22 DEBUG EnvisaLinkZoneTimerDump 00000000F8FFF0FF0000F2FF503EA2F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:27 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:55:27 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:55:27 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:27 DEBUG Received: ^02,00$
                Mar-14 11:55:27 DEBUG CommandAck 02,00
                Mar-14 11:55:27 DEBUG Received: %FF,00000000F7FFEFFF0000F1FF4F3EA1F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:27 DEBUG EnvisaLinkZoneTimerDump 00000000F7FFEFFF0000F1FF4F3EA1F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:32 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:32 DEBUG Received: ^02,00$
                Mar-14 11:55:32 DEBUG CommandAck 02,00
                Mar-14 11:55:32 DEBUG Received: %FF,00000000F6FFEEFF0000F0FF4E3EA0F5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:32 DEBUG EnvisaLinkZoneTimerDump 00000000F6FFEEFF0000F0FF4E3EA0F50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
                Mar-14 11:55:37 DEBUG Received: %00,01,1C28,08,00, DISARMED CHIME Ready to Arm $
                Mar-14 11:55:37 DEBUG VirtualKeypadUpdate 01,1C28,08,00, DISARMED CHIME Ready to Arm
                Mar-14 11:55:37 DEBUG Request: DumpZoneTimers ^02,$
                Mar-14 11:55:37 DEBUG Received: ^02,00$
                Mar-14 11:55:37 DEBUG CommandAck 02,00
                Mar-14 11:55:37 DEBUG Received: %FF,00000000F5FFEDFF0000EFFF4D3E9FF5000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000$
                Mar-14 11:55:37 DEBUG EnvisaLinkZoneTimerDump 00000000F5FFEDFF0000EFFF4D3E9FF50000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000000000000000
