Password refused
    Password refused
    moved to linux. rermoved and replaced PI to .31
    can't get it to accept the connection
    any idea's ??
    system has been soooo stable for years
    Geary
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro
    the password you need to use is the one you use to enter the local webpage:
    http://envisalink/
    default user/password is user/user
    if you don't remember it and if you still have your windows HS3 install, edit Config/EnvisaLink.ini to look it up.
    also you can't have several programs connecting to the EnvisaLink board at the same time so you need to disable the EnvisaLink plugin on your windows HS3
      thanks.. I can log into the webpage with known password
      but can't connect w/ HS..
      going to recycle power , close all windows and see what happens
      G
        Go to the Network page and on the bottom, verify Envisalink TPI Status. If it is online, it will registered the IP address of the connected client.
        As Spud indicated it can only have one connection
          not getting network attach.. off and troubleshootign
            is there a port ??
              but EyezOn shows as registered..
                forget about the eyezon webpage
                you need to access the local webpage, can you access this url:
                http://envisalink
                it should ask you a user/password, which is by default user/user
                  server not found ??
                  btw.. is there any reason to upgrade to the 4 ?
                    I gather you know the IP address of the EVL? If not you will need to establish that first. If http://envisalink doesn't work, do a network scan or use an app like Fing available for iOS or android.
                    No reason to upgrade.
                    http://forum.eyez-on.com/FORUM/viewtopic.php?f=6&t=2027
                    There are other factors but that would be if you or your installer is through Connect2Go which is the professional installer side.
