Alarm trip events
Could you create a virtual device a zone and for a partition and then set them based on the invoking partition? E.g. when I say partition ANY then the partition virtual device would hold the info of the actual partition. Would certainly simplify my events.
Have you tried to use the EnvisaLink trigger "Zone Open"? You should be able to select "Any" as the zone parameter. However, then there is no easy way to get the zone name that was tripped, you would need a script that loop over all the zones and check their status.
Alarm trip events
Hiya-
I'd like to send a notification if any zone is tripped between certain hours of the evening.
I realize that I could just make one event per zone but I wondered if there was any more elegant way?
So if 'any' zone gets tripped is there a way to get the zone name passed to the notification in that case? So I could say that "Kid bedroom window" was tripped or whatever.
Does this make sense?
-SpiflTags: None
