Passing Disarm code from HSTouch to DSC Plugin
  • Passing Disarm code from HSTouch to DSC Plugin
    Hello,
    I am new to writing scripts and I have created an HSTouch screen where I can have someone type in their alarm code to arm/disarm the system, then saves it in parm(0) and then passes it to the script. I wondered if you could take a quick look at it to make sure I'm doing this correctly. I'm using the code Spud had in the DSC user guide.
    I've attached below a screen where I pull in the code from an HSTouch element and then run the below script:
    Sub Main(ByVal parm As Object)
    Dim inputcode
    inputcode = parm(0).ToString 'Gets input code from HST
    hs.PluginFunction("EnvisaLink", "", "SendKeystrokeString", new object[] { 1, inputcode]);return 0;
    End Sub
    HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 887 Devices, 515 Events
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
    I don't know if this is it, but it looks like your curly brace is closed with a square bracket:
    { 1, inputcode]
      also, the example from the user guide is a C# script, here you are using VB, so I think the call to the plugin function should be:
      hs.PluginFunction("EnvisaLink", "", "SendKeystrokeString", new Object() { 1, inputcode})
        Thank you for the help! I've attached what I believe to be a vb script that includes all the above.
        Plugin's:
