Arm Stay/Arm Away button at panel - Device status
  • Arm Stay/Arm Away button at panel - Device status
    Hi Spud,
    When someone presses the Arm Stay or Arm Away button at the panel the partition device goes to "Exit Delay in Progress" for both buttons. I'm assuming that the system must receive different codes depending on which button is pressed, is there a way to have the partition device show "Arm Stay Delay" if the Arm Stay button is pressed and "Exit Delay in Progress" if Arm Away is pressed?
    HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 887 Devices, 515 Events
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
    The plugin doesn't know which button is pressed, it just receives one "Exit delay in progress" message when the partition changes to this state, and then a "Armed Stay" or "Armed Away" message.
    As far as I know there is no "Arm Stay Delay" type of message.
