Log file only showing Open/Closed events
    Hi
    I am trying to build an event to report any tamper or battery issues from my DSC system.
    Looking at the documentation, I tought that if i builded an event with a triggering type : Verbose Trouble Status with the trouble: SensorZoneLowBattery or SensorZoneTamper I would be advised of any battery or tamper issue with a device but I don't.
    I simulate a tamper on one of my device, I received a temper messsage from my EYEZON account but never received the message from HS3
    I went in the C:\Program Files (x86)\HomeSeer HS3\Logs\Envisalink.log file to see if the Tamper event was present but could not find it.
    I have a PC1864 with EVL3 installed, all sensors HS3 devices have the log enable,
    Anyone could point me in the right direction to fix my problem?
    Also is there any way to report the specific Trouble via an email or Pushover ? (is there a variable created that could be linked in a message ?)
    thanks for any help
    ??? does the log level need to be set to other than info to have acces to Trouble ?
