My HS3 log file is reporting that about every 4 minutes, the Envisalink plug-in is reporting "status change: Ready". But the status isn't changing every 4 minutes, the status remains in the "Ready" state for hours upon hours, yet I see these messages about every 4 minutes. Attached is a snippet from the log file. Any ideas why this might be happening?
Status change report every 4 minutes
I have seen this happening when the panel battery is low. If you set the log level to debug you may get more information about what is happening.
If you simply want to hide this log messages, then click on the partition device, and from the EnvisaLink tab you can disable log for partition state change.
The request poll occurs every 2 minutes and this is not configurable but this is not what's causing the problem.
The following lines appear every 4 minutes and the value sent along with VerboseTroubleStatus means "Service is required". It usually means the battery needs to be replaced. The partition ready message is a side effect of this.
Code:Jun-02 07:03:05 DEBUG VerboseTroubleStatus 01 Jun-02 07:03:05 DEBUG KeypadLedStatePartition1Only 80 Jun-02 07:03:05 DEBUG KeypadLedflashStatePartition1Only 00 Jun-02 07:03:05 DEBUG KeypadLedStatePartition1Only 91 Jun-02 07:03:05 DEBUG PartitionReady 1
