Can a flag or similar functionality be utilized to track the status of chime mode? I'd like to be able to use an if/then function to track if it's been turned off at the keypad to turn it on at night when arming either via keypad or programmatically.
Can Envisalink DSC plugin track status of chime mode?
There is a "Chime Enabled" trigger and a "Chime Disabled" trigger, so you can create some events to try to track the current chime mode using a virtual device,
And according to https://support.reedsecurity.com/por...try-exit-beeps, sending *4 should turn it on/off, so you should be able to change it using a "Send Keystroke String" event action.
Because the “Chime” Virtual Device has only one control “Toggle”. On and off are Status only. I am setting On (100) and Off (0) with an immediate script since they are not control options. You could certainly add On and Off Status/Value pairs, but I prefer to avoid controls for Virtual Devices I won’t control manually.
HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by randy View PostYes, the Envisalink plug-in provides the Trigger. It is Envisalink: Message Received. If the plug-in is installed it should be in your Trigger drop down.
