EnvisaLink DSC Plug-in - Feature requests
This is a sticky topic.
    #46
    Originally posted by terrence989 View Post
    Hi,
    I am HS3 PRO user, please recommend which interface work better for the below : -
    Envisalink EVL3 or DSC IT-100 interface
    Thank you
    This plugin is only for the EVL3. The HomeSeer or Blade plugins can only be used with the IT-100.
    Originally posted by rprade
      #47
      Hi,
      Thank you
      I have had all 3, the 100, 5403 and EVL
      I prefer the ethernet interface over Serial
      Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
        #48
        Basic Log Event for Alarm Status Change
        Request to log event to System Log on Alarm Status Change for the DSC Plugin.
          #49
          done in version 3.0.0.15 available here
          now all partition and zone status changes are logged at info level
            #50
            Selective logging within Info
            Hi Spud,
            I'm getting a whopping amount of logging in Info mode because of a motion detector which happens to be central to most traffic in the house.
            1- Any chance of implementing selective Info logging by Zone where I could pick which zones get logging.
            2- Let me push my luck just a bit further. Could you also create another Envisalink action that would turn logging Off/On for a particular zone? This would allow users to set up events to activate logging for particular zones depending on who disarms the panel, sweet.
              #51
              Originally posted by claude View Post
              Hi Spud,
              yeah, I will make the log configurable at the device level in next version
                #52
                in version 3.0.0.17 available here, I have added the possibility to prevent status change log for any zone or partition device.
                open a Zone or Parition device, you will see a new EnvisaLink tab from which you can disable log:
                  #53
                  Hi Spud,
                  EDIT - Just tried it on .17: works great, thanks
                  EDIT - Any chances on this one? For me, this one complements #1. Normally, I don't want to flood the log with Motion detector traffic; but for someone I gave a temporary password to come and do work while I'm away, I would like the ability to turn on logging for certain zones (ex: Motion detector).
                  See edits above
                    #54
                    yes, I will add this new Action in the next version
                      #55
                      Not sure it's possible but could you display how the zones are configured? I just saw a great example in Rien du Pre's Caddx plugin with a whole column for zone types.
                      http://board.homeseer.com/showpost.p...3&postcount=10
                      Would be super cool.
                        #56
                        How about a status bar we can drag into HSTouch to show whether we are armed or not.
                          #57
                          unfortunately I don't think there is any way to get the zone type using the envisalink API.
                            #58
                            as per our discussion in this thread I think you can show the partition device status in a text element.
                              #59
                              Yeah, I was afraid of that but figured I'd ask any way.
                                #60
                                A better string for partition device
                                Hi Spud,
                                I was used with my later Caddx to have a script maintaining the list of opened zone and updating a device string at every change.
                                This would change the Partition device text string from "Not Ready"
                                to "Opened zones: Entry door, main-room window left".
                                I just adapted the script for Envisalink-DSC and HS3, but did not find a nice way to trigger it (Best would be "at any change in any zone").
                                I did have a callback instruction in my HS2 setup, but do not feel comfortable using this in HS3.
                                I guess this could be a nice feature for the plugin, and a more elegant way than external script.
                                A new envisalink trigger "at any change in any zone" would be appreciated as an alternative.
                                Pierre
