EnvisaLink DSC Plug-in - Feature requests
This is a sticky topic.
  • #91
    respond
    Aug-30 10:44:59 AM
    EnvisaLink DEBUG postBackProc data: password=pat20aug Aug-30 10:41:29 AM EnvisaLink DEBUG LoginInteraction 0 Aug-30 10:41:29 AM EnvisaLink ERROR Wrong password Aug-30 10:41:29 AM EnvisaLink DEBUG CommandAcknowledge 005 Aug-30 10:41:29 AM EnvisaLink DEBUG LoginInteraction 3 Aug-30 10:41:29 AM EnvisaLink DEBUG Request: StatusReport Aug-30 10:41:29 AM EnvisaLink DEBUG Request: Poll Aug-30 10:41:29 AM EnvisaLink DEBUG Request: TimeStampControl 1 Aug-30 10:41:29 AM EnvisaLink DEBUG Request: NetworkLogin pat20aug Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:16 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:15 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:14 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:13 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:12 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:11 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:10 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:9 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:8 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:7 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:6 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:5 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:4 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:3 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:2 Aug-30 10:41:29 AM EnvisaLink DEBUG Zone Device Found: Z:1 Aug-30 10:41:28 AM EnvisaLink DEBUG Partition Device Found: P:2 Aug-30 10:41:28 AM EnvisaLink DEBUG Partition Device Found: P:1 Aug-30 10:41:27 AM EnvisaLink INFO EnvisaLink version 3.0.0.30
    • #92
      Originally posted by Gallina View Post
      Aug-30 10:44:59 AM
      So your log says "Wrong password". The password you need to put in the config page is the one you use to access the EnvisaLink's local webpage, the default one is "user".
      • #93
        User Access device value
        Hi,
        I am using the Envisalink user access device string for speaking ("Hello Pierre" when disarming) .
        This string is populated, I guess by the plugin, with the name of the homeseer user, witch is very handsome and easy.
        I just wish that the added text "Disarmed by " was customizable for non-english users. (I have to parse-it myself in the present)
        I wish the device value was also updated with the DSC user number.
        This way I could fire special events (calling my phone) for some users (when out of schedule for example).
        I hope it won't be to difficult to add this to a future version.
        May I also suggest to include this http://forums.homeseer.com/showthread.php?t=174121, that I feel should be built-in.
        Pierre
        • #94
          Originally posted by Pierre View Post
          Hi,
          Internationalization is not the strong suit of HS3, it would be a big job for me to allow to customize all hard coded english text in all my plugins. So I don't think I will do it for now. As you said the workaround is scripting, and now you can use the DSC user id, see below.
          done in version 3.0.0.31 available here
          I will think about this, however if I do it it will likely be a new device rather than overwriting the partition device string.
          • #95
            Originally posted by dmcentire View Post
            I appreciate the idea of an option to "not create deleted devices" that sounds pretty good.
            The alpha idea doesn't work.. see snapshot below.
            Out of curiosity, what language are the plug-ins written in? I'm a developer myself and might be interested in making something.
            In version 3.0.0.31 available here., I have added the option to not automatically recreate missing devices at start up. The new setting is in the Config page and is called "Do not recreate missing devices".
            All my plugins are written in C#
            • #96
              Thank you Spud for this new release and for your efforts on the plugin.
              • #97
                Thank you!
                Sorry for the delayed reply here but I wanted to say thank you for adding this most recent feature. I was able to delete the unused zones from HS3 and now my device lists are cleaner.
                Thank you again!
                • #98
                  Flood Sensor
                  Hi Spud,
                  Could i please request flood sensor being added as a zone type? i know i can manually tweak things but not sure if it can be hardcoded?
                  Much appreciated.
                  • #99
                    Originally posted by deanrparry View Post
                    Hi Spud,
                    Much appreciated.
                    in version 3.0.0.37 I added a "Water" zone type
                    https://forums.homeseer.com/showthread.php?t=161219
                    • You sir are amazing! thank you so much
                      • I see the debug reports back status of keypad panels is there anyway we can get this back to the device zone 29-32?
                        • Originally posted by deanrparry View Post
                          what message is that, could you post your debug logs?
                          why zone 29-32?
                          • Zone 29-32 are allocated specifically by the panel for wireless keypads you cannot allocate sensors to these zones. I will forward logs
                            • Originally posted by spud View Post
                              why zone 29-32?
                              https://pastebin.com/1HyRaxtR
                              • Multiple Panels
                                Does this plugin support multiple panels? I have a remote site connected via VPN and use a znet for control. Since I can get to it remotely could it control two panels?
