Getting this error in the log with BETA
  • Getting this error in the log with BETA
    9/12/2013 7:17:41 PM - EnvisaLink - ERROR Index and length must refer to a location within the string.Parameter name: length
    not sure what this means ... everything seems to be working.
    Do you need to register the Beta if you want to run it beyond 30 days?
    Thanks.
    Is this HS2 or HS3?
    Could you set the log level to debug in the config page and capture a full log?
    I need more info, when does this error happen?
    Yes you need to register beyond 30 days. Right now the package in the Beta testing thread is actually the official version which is also in the updater.
      Log ... not seeing the error now?
      9/12/2013 11:14:57 PM Startup Settings Loaded.
      9/12/2013 11:14:57 PM Startup Current sunrise/sunset values calculated.
      9/12/2013 11:14:57 PM Startup HSPhone external interface class started.
      9/12/2013 11:14:57 PM Startup Local voice recognition class started.
      9/12/2013 11:14:57 PM Startup Database SAVE process started.
      9/12/2013 11:14:57 PM Startup Loading configuration file ...
      9/12/2013 11:14:57 PM System Loading device types file...
      9/12/2013 11:14:57 PM Database Opening (Mode=Read) up HomeSeer database: C:\Program Files (x86)\HomeSeer 2\config\HSConfig.mdb
      9/12/2013 11:14:57 PM Database Loading Devices...
      9/12/2013 11:14:58 PM Load Config 101 total devices loaded.
      9/12/2013 11:14:58 PM Load Config Checking device type settings for all devices...
      9/12/2013 11:14:58 PM Load Config Finished checking device type settings.
      9/12/2013 11:14:58 PM Load Config Loading Events...
      9/12/2013 11:14:58 PM Load Config 74 total events loaded.
      9/12/2013 11:14:58 PM Database HomeSeer configuration database C:\Program Files (x86)\HomeSeer 2\config\HSConfig.mdb has been closed.
      9/12/2013 11:14:58 PM Startup HomeSeer version is: 2.5.0.81
      9/12/2013 11:14:58 PM Startup Starting remoting (Remote client connection monitor)
      9/12/2013 11:14:58 PM Startup Creating Speaker Client Interface Object...
      9/12/2013 11:14:58 PM Startup Initializing phone interface...
      9/12/2013 11:14:58 PM HSPhone HomeSeer Phone Web Interface initializing.
      9/12/2013 11:14:58 PM Startup Checking for pending updates to be installed...
      9/12/2013 11:14:58 PM Startup Restoring Device Status...
      9/12/2013 11:14:58 PM Z-Wave :- :- :- :- :- :- :- :- Initializing Z-Wave Interface -: -: -: -: -: -: -: -:
      9/12/2013 11:14:58 PM Z-Wave Initializing Z-Wave Interface on COM port: 3 at 115K baud.
      9/12/2013 11:14:58 PM Z-Wave Getting node information from controller...
      9/12/2013 11:15:00 PM Z-Wave Z-Wave Serial API version: 4
      9/12/2013 11:15:00 PM Z-Wave Z-Wave interface node ID: 1, Home ID: 003D383D
      9/12/2013 11:15:00 PM Z-Wave Found 35 Z-Wave nodes in interface node ID 1
      9/12/2013 11:15:00 PM Z-Wave Controller Manufacturer: HomeSeer Tech, ID=0x2, Type=0x1
      9/12/2013 11:15:00 PM Z-Wave Controller firmware version: 1.17
      9/12/2013 11:15:01 PM Z-Wave This Z-Wave PC Controller Library Version is: Z-Wave 3.28 (ZDK Version 5.03)
      9/12/2013 11:15:01 PM Z-Wave This Z-Wave PC Controller is Type: ZW_LIB_INSTALLER
      9/12/2013 11:15:01 PM Z-Wave Z-Wave services for communications to nodes utilizing the SECURITY COMMAND CLASS were successfully started.
      9/12/2013 11:15:01 PM Z-Wave -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      9/12/2013 11:15:01 PM Startup Checking for available plug-ins
      9/12/2013 11:15:01 PM Plug-In Found plug-in: X10 CM11A/CM12U, version: 2.2.0.4
      9/12/2013 11:15:01 PM Plug-In Found plug-in: EnvisaLink, version: 1.0.0.4
      9/12/2013 11:15:01 PM Plug-In Found plug-in: HSTouch Server, version: 1.0.0.72
      9/12/2013 11:15:01 PM Plug-In Found plug-in: HSTouch Android, version: 1.0.0.2
      9/12/2013 11:15:01 PM Plug-In Found plug-in: HSTouch iPhone, version: 1.0.0.2
      9/12/2013 11:15:01 PM Plug-In Found plug-in: iTunes, version: 2.5.0.12
      9/12/2013 11:15:02 PM Plug-In Found plug-in: RCS X10 Thermostat, version: 2.0.0.105
      9/12/2013 11:15:03 PM Plug-In Found plug-in: WebCam, version: 2.0.0.2
      9/12/2013 11:15:03 PM Plug-In Found plug-in: ZWave Thermostats, version: 2.5.0.53
      9/12/2013 11:15:03 PM Startup Initializing Plug-Ins
      9/12/2013 11:15:03 PM Plug-In Initializing Plug-in: HSTouch Server
      9/12/2013 11:15:03 PM Plug-In Finished initializing plug-in HSTouch Server
      9/12/2013 11:15:03 PM Plug-In Initializing Plug-in: HSTouch iPhone
      9/12/2013 11:15:03 PM Plug-In Finished initializing plug-in HSTouch iPhone
      9/12/2013 11:15:03 PM Plug-In Initializing Plug-in: ZWave Thermostats
      9/12/2013 11:15:03 PM Plug-In Finished initializing plug-in ZWave Thermostats
      9/12/2013 11:15:03 PM Plug-In Interface EnvisaLink is running as a trial, 30 days remaining.
      9/12/2013 11:15:03 PM Plug-In Initializing Plug-in: EnvisaLink
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:7
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:8
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:6
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:5
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:4
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:3
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:2
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Zone Device Found: Z:1
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Partition Device Found: P:1
      9/12/2013 11:15:03 PM Plug-In Finished initializing plug-in EnvisaLink
      9/12/2013 11:15:03 PM Plug-In Initializing X10 Plug-in: X10 CM11A/CM12U On COM Port 1
      9/12/2013 11:15:03 PM Plug-In Initializing Plug-in: X10 CM11A/CM12U
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Request: NetworkLogin coors
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Request: TimeStampControl 1
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Request: StatusReport
      9/12/2013 11:15:03 PM EnvisaLink DEBUG Request: Poll
      9/12/2013 11:15:03 PM EnvisaLink DEBUG LoginInteraction 3
      9/12/2013 11:15:03 PM Info Initializing CM11A/12U on COM port 1
      9/12/2013 11:15:03 PM EnvisaLink DEBUG CommandAcknowledge 005
      9/12/2013 11:15:03 PM EnvisaLink DEBUG LoginInteraction 1
      9/12/2013 11:15:03 PM Plug-In Finished initializing X10 interface X10 CM11A/CM12U
      9/12/2013 11:15:04 PM Plug-In Finished initializing infrared interface None
      9/12/2013 11:15:04 PM Web Server Local IP address (subnet) is: 192.168.1.139 (255.255.255.0)
      9/12/2013 11:15:04 PM Web Server UPNP Discovery started
      9/12/2013 11:15:04 PM Web Server Web Server started on port 8082
      9/12/2013 11:15:04 PM Startup Initializing email 1 0
      9/12/2013 11:15:04 PM Startup Start automation engine...
      9/12/2013 11:15:04 PM email Email receive thread started
      9/12/2013 11:15:04 PM Startup This version of HomeSeer is registered.
      9/12/2013 11:15:04 PM Startup Initializing Speaker Client Interface
      9/12/2013 11:15:04 PM Speech Listening for remote speaker connections on port 8742
      9/12/2013 11:15:04 PM Startup Starting Event Scheduler...
      9/12/2013 11:15:04 PM Z-Wave Starting Z-Wave Polling...
      9/12/2013 11:15:04 PM Z-Wave Starting 'Z-Wave Health' Process Starter...
      9/12/2013 11:15:04 PM Startup Checking HTTP connection...
      9/12/2013 11:15:04 PM Web Server Web Server authorized local login successful from: 127.0.0.1 User: Dhuras
      9/12/2013 11:15:04 PM Startup Updater services starting...
      9/12/2013 11:15:04 PM Startup Starting DDNS service...
      9/12/2013 11:15:04 PM Startup Running the Startup.txt Script
      9/12/2013 11:15:04 PM TTS Speak ():Welcome to Home Seer
      9/12/2013 11:15:04 PM email Initializing POP email, found 424 messages
      9/12/2013 11:15:04 PM EnvisaLink DEBUG CommandAcknowledge 055
      9/12/2013 11:15:04 PM EnvisaLink DEBUG CommandAcknowledge 001
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 001
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 002
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 003
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 004
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 005
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 006
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 007
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 008
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 009
      9/12/2013 11:15:04 PM EnvisaLink DEBUG ZoneRestored 010
      9/12/2013 11:15:04 PM Error Running script, script run or compile error in file: restore_state.txt53:File not found in line 8 More info: File not found
      9/12/2013 11:15:04 PM Startup Start up complete.
      9/12/2013 11:15:04 PM Web Server Web Server authorized local login successful from: 192.168.1.139 User: Dhuras
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 011
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 012
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 013
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 014
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 015
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 016
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 017
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 018
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 019
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 020
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 021
      9/12/2013 11:15:05 PM EnvisaLink DEBUG ZoneRestored 022
      9/12/2013 11:15:06 PM EnvisaLink DEBUG ZoneRestored 023
      9/12/2013 11:15:06 PM EnvisaLink DEBUG ZoneRestored 024
      9/12/2013 11:15:06 PM EnvisaLink DEBUG ZoneRestored 025
      9/12/2013 11:15:06 PM EnvisaLink DEBUG ZoneRestored 026
      9/12/2013 11:15:06 PM EnvisaLink DEBUG ZoneRestored 027
      9/12/2013 11:15:06 PM EnvisaLink DEBUG ZoneRestored 028
      9/12/2013 11:15:07 PM EnvisaLink DEBUG ZoneRestored 029
      9/12/2013 11:15:07 PM EnvisaLink DEBUG ZoneRestored 030
      9/12/2013 11:15:07 PM EnvisaLink DEBUG ZoneRestored 031
      9/12/2013 11:15:07 PM EnvisaLink DEBUG ZoneRestored 032
      9/12/2013 11:15:07 PM EnvisaLink DEBUG PartitionReady 1
      9/12/2013 11:15:07 PM EnvisaLink DEBUG PartitionisBusy 2
      9/12/2013 11:15:07 PM EnvisaLink DEBUG TroubleLedoff 1
      9/12/2013 11:15:07 PM EnvisaLink DEBUG TroubleLedoff 2
      9/12/2013 11:15:07 PM EnvisaLink DEBUG KeypadLedStatePartition1Only 81
      9/12/2013 11:15:08 PM ZWave Thermostats Devices Updated for thermostat: Z-Wave CT100 Thermostat
      9/12/2013 11:15:17 PM ZWave Thermostats 1 Thermostats converted Successfully.
      9/12/2013 11:15:23 PM Network Speaker client connected from: 127.0.0.1
        Error Message is back ... log excerpt w/DEBUG on imbedded in message below...
        9/13/2013 8:13:37 AM Web Server Web Server authorized login successful from: 24.114.79.141 User: dhuras
        9/13/2013 8:15:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:15:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:17:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:17:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:19:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:19:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:21:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:21:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:23:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:23:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:23:36 AM Device Update Device: Z-Wave Interface Z-Wave Everspring Relative Humidity Inst 2 value set to 72 (7200/%)
        9/13/2013 8:23:38 AM Device Update Device: Z-Wave Interface Z-Wave EverspringTemperature Inst 1 value set to 11.1 (1110/C)
        9/13/2013 8:24:11 AM X10 Received O10 (Sensors and Beepers Front Door Motion) O Off
        9/13/2013 8:25:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:25:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:25:55 AM Device Update Device: Z-Wave Interface Z-Wave Front Dr Motion Detector value set to 0 ()
        9/13/2013 8:27:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:27:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:29:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:29:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:31:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:31:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:33:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:33:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:35:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:35:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:37:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:37:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:39:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:39:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:40:04 AM Event Event Trigger "email recieved"
        9/13/2013 8:40:04 AM Event Running script in background: email_actions.txt
        9/13/2013 8:40:04 AM TTS Speak ():You have mail! The subject is
        9/13/2013 8:40:04 AM TTS Speak ():Save 50% on photo books + check out our new photo book App.
        9/13/2013 8:41:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:41:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:41:30 AM Device Update Device: Z-Wave Interface Z-Wave CT100 Battery Battery Level 73%
        9/13/2013 8:43:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:43:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:45:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:45:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:47:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:47:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:49:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:49:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:50:22 AM Event Event Trigger "email recieved"
        9/13/2013 8:50:22 AM Event Running script in background: email_actions.txt
        9/13/2013 8:50:22 AM TTS Speak ():You have mail! The subject is
        9/13/2013 8:50:22 AM TTS Speak ():iPhone 5c and iPhone 5s coming to Best Buy on Sept 20th.
        9/13/2013 8:50:28 AM Device Update Device: Z-Wave Interface Z-Wave Front Dr Motion Luminance value set to 13 (1300/%)
        9/13/2013 8:50:28 AM Error (2) Sensor Multilevel Report for type Air_Temperature received, but the corresponding device Node ID cannot be found.(2) Node/Instance=3/-1
        9/13/2013 8:51:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:51:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:53:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:53:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:55:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:55:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:55:13 AM Web Server Web Server authorized login successful from: 142.205.241.253 User: dhuras
        9/13/2013 8:57:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:57:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 8:59:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 8:59:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:01:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:01:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:03:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:03:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:05:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:05:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:07:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:07:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:09:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:09:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:10:59 AM Event Event Trigger "email recieved"
        9/13/2013 9:10:59 AM Event Running script in background: email_actions.txt
        9/13/2013 9:10:59 AM TTS Speak ():You have mail! The subject is
        9/13/2013 9:11:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:11:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:12:59 AM Device Update Device: Z-Wave Interface Z-Wave CT100 Battery Battery Level 65%
        9/13/2013 9:13:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:13:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:15:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:15:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:15:55 AM EnvisaLink ERROR Index and length must refer to a location within the string.Parameter name: length
        9/13/2013 9:15:55 AM EnvisaLink DEBUG Stack: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at EnvisaLink.Communications.TpiResponse.Parse(String data) at EnvisaLink.Communications.Reciever.Run() at EnvisaLink.Communications.Communicator.ListenForData()
        9/13/2013 9:15:55 AM EnvisaLink INFO Reconnection OK
        9/13/2013 9:16:01 AM EnvisaLink ERROR Index and length must refer to a location within the string.Parameter name: length
        9/13/2013 9:16:01 AM EnvisaLink DEBUG Stack: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at EnvisaLink.Communications.TpiResponse.Parse(String data) at EnvisaLink.Communications.Reciever.Run() at EnvisaLink.Communications.Communicator.ListenForData()
        9/13/2013 9:16:01 AM EnvisaLink INFO Reconnection OK
        9/13/2013 9:16:29 AM Device Update Device: Z-Wave Interface Z-Wave Everspring Relative Humidity Inst 2 value set to 70 (7000/%)
        9/13/2013 9:16:31 AM Device Update Device: Z-Wave Interface Z-Wave EverspringTemperature Inst 1 value set to 11.5 (1150/C)
        9/13/2013 9:17:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:17:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:19:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:19:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:21:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:21:04 AM EnvisaLink DEBUG CommandAcknowledge 000
        9/13/2013 9:21:17 AM Event Event Trigger "email recieved"
        9/13/2013 9:21:17 AM Event Running script in background: email_actions.txt
        9/13/2013 9:21:59 AM Device Control Device: Z-Wave Special Occasion Z-Wave S.O. Foyer (Q55) OFF
        9/13/2013 9:23:04 AM EnvisaLink DEBUG Request: Poll
        9/13/2013 9:23:04 AM EnvisaLink DEBUG CommandAcknowledge 000
          the error is due to a message received from the panel, that the plugin is not able to parse, but there is not enough info in the log for me to know which message cause this.
          I have added some more logs in the attached dll, could you try to update your dll with the one in the attached zip and recapture logs showing the error
          thanks a lot.
            DEBUG Log with new DLL
            ..hopefully this provides you with what you need, THanks.
            13/2013 8:37:27 PM EnvisaLink DEBUG Request: Poll
            9/13/2013 8:37:27 PM EnvisaLink DEBUG Parse: data =19:37:38 50000025
            9/13/2013 8:37:27 PM EnvisaLink DEBUG CommandAcknowledge 000
            9/13/2013 8:39:27 PM EnvisaLink DEBUG Request: Poll
            9/13/2013 8:39:27 PM EnvisaLink DEBUG Parse: data =19:39:38 50000025
            9/13/2013 8:39:27 PM EnvisaLink DEBUG CommandAcknowledge 000
            9/13/2013 8:39:44 PM EnvisaLink DEBUG Parse: data =19:39:55 5609B
            9/13/2013 8:39:44 PM EnvisaLink ERROR Index and length must refer to a location within the string.Parameter name: length
            9/13/2013 8:39:44 PM EnvisaLink DEBUG Stack: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at EnvisaLink.Communications.TpiResponse.Parse(String data) at EnvisaLink.Communications.Reciever.Run() at EnvisaLink.Communications.Communicator.ListenForData()
            9/13/2013 8:39:44 PM EnvisaLink INFO Reconnection OK
            9/13/2013 8:39:46 PM Event Event Trigger "Z-Wave Foyer (delayed action)"
            9/13/2013 8:39:46 PM Device Control Device: Z-Wave Interface Z-Wave Foyer (Q16) OFF
            9/13/2013 8:39:46 PM Event Deleting event after run: "Delayed Actions Z-Wave Foyer (delayed action)"
            9/13/2013 8:39:50 PM EnvisaLink DEBUG Parse: data =19:40:01 5609B
            9/13/2013 8:39:50 PM EnvisaLink ERROR Index and length must refer to a location within the string.Parameter name: length
            9/13/2013 8:39:50 PM EnvisaLink DEBUG Stack: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at EnvisaLink.Communications.TpiResponse.Parse(String data) at EnvisaLink.Communications.Reciever.Run() at EnvisaLink.Communications.Communicator.ListenForData()
              Thanks.
              The problem was caused by the "Ring Detected" message, I fixed it in version 1.0.0.5 for HS2, and version 3.0.0.2 for HS3.
              You can find the new packages there:
              HS2: http://board.homeseer.com/showthread.php?t=160342
              HS3: http://board.homeseer.com/showthread.php?t=161219
                Excellent!
                Thanks.
