Zone device does not update
    I have a quick quesiton.
    I noticed that my zones weren't updating and decided to check the envisalink portal to see if I can find the issue. What I Found is that the zones in question are still showing a red status with the alert "closed ## minutes ago".
    In homeseer, they show as open. I'm assuming that until envisalink showes as closed for those zones, the status on homeseer won't change?
    Is there a way to change that?
    HS4Pro Win10 | Fire Tablet touchscreen client, Android Phones and Tablets | Jon00 | Smartthings | Philips Hue | Trane | Caseta | Nanoleaf | Ring | August | Evolve | Aladdin | Amazon Alexa/IFTT
    no, the status in HS should change as soon as you close the zone.
    please set the log level to debug, and see what message the plugin receives when you close a zone.
      Ok I set it to debug and restarted. It is still exhibiting the same behavior.
      Here is the log.
      11/3/2013 9:56:19 PM - EnvisaLink - DEBUG ZoneRestored 006
      11/3/2013 9:56:19 PM - EnvisaLink - DEBUG ZoneRestored 007
      11/3/2013 9:56:19 PM - EnvisaLink - DEBUG ZoneRestored 008
      11/3/2013 9:56:19 PM - EnvisaLink - DEBUG ZoneRestored 009
      11/3/2013 9:56:19 PM - EnvisaLink - DEBUG ZoneRestored 010
      11/3/2013 9:56:19 PM - EnvisaLink - DEBUG ZoneRestored 011
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG Request: Poll
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG ZoneRestored 018
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG ZoneRestored 019
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG ZoneRestored 020
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG ZoneRestored 021
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG ZoneRestored 022
      11/3/2013 9:58:18 PM - EnvisaLink - DEBUG ZoneRestored 023
      11/3/2013 9:58:19 PM - EnvisaLink - DEBUG CommandAcknowledge 000
      11/3/2013 9:58:19 PM - EnvisaLink - DEBUG ZoneRestored 024
      11/3/2013 9:58:19 PM - EnvisaLink - DEBUG ZoneRestored 025
      11/3/2013 9:58:19 PM - EnvisaLink - DEBUG ZoneRestored 026
      11/3/2013 9:58:19 PM - EnvisaLink - DEBUG ZoneRestored 027
      11/3/2013 9:58:19 PM - EnvisaLink - DEBUG ZoneRestored 028
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG Request: Poll
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG ZoneRestored 035
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG ZoneRestored 036
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG ZoneRestored 037
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG ZoneRestored 038
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG ZoneRestored 039
      11/3/2013 10:00:18 PM - EnvisaLink - DEBUG ZoneRestored 040
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG CommandAcknowledge 000
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 041
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 042
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 043
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 044
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 045
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 046
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 047
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 048
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 049
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 050
      11/3/2013 10:00:19 PM - EnvisaLink - DEBUG ZoneRestored 051
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG Request: Poll
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG ZoneRestored 058
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG ZoneRestored 059
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG ZoneRestored 060
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG ZoneRestored 061
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG ZoneRestored 062
      11/3/2013 10:02:18 PM - EnvisaLink - DEBUG ZoneRestored 063
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG CommandAcknowledge 000
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG ZoneRestored 064
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionReady 1
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionisBusy 2
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionisBusy 3
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionisBusy 4
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionisBusy 5
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionisBusy 6
      11/3/2013 10:02:19 PM - EnvisaLink - DEBUG PartitionisBusy 7
      11/3/2013 10:04:18 PM - EnvisaLink - DEBUG Request: Poll
      11/3/2013 10:04:18 PM - EnvisaLink - DEBUG ZoneOpen 004
      11/3/2013 10:04:18 PM - EnvisaLink - DEBUG PartitionReadyForceArmingEnabled 1
      11/3/2013 10:04:18 PM - EnvisaLink - DEBUG ZoneRestored 004
      11/3/2013 10:04:18 PM - EnvisaLink - DEBUG PartitionReady 1
      11/3/2013 10:04:18 PM - EnvisaLink - ERROR Wrong checksum in response detected. Data = 22:03:02 60900
      11/3/2013 10:04:18 PM - EnvisaLink - DEBUG Stack: at EnvisaLink.Communications.TpiResponse.Parse(String data) at EnvisaLink.Communications.Reciever.Run() at EnvisaLink.Communications.Communicator.ListenForData()
      11/3/2013 10:04:18 PM - EnvisaLink - INFO Reconnection OK
      11/3/2013 10:04:19 PM - EnvisaLink - DEBUG CommandAcknowledge 000
        so in this example you opened zone 4 and then closed it, and HS3 zone 4 device still says it's opened?
        do you always get the following error when you open or close a zone?
        This error is caused by a message that doesn't make any sense, it says a zone is open but it doesn't say which one, which may be the cause of your problem.
        Please try the attached version. In this version the plugin ignore messages that don't make sense and log a warning.
        Also, could you tell me which firmware you are running, you can see that at the bottom of the local web page in network tab: http://envisalink/3
          It wasn't occuring the first few days so I'm not sure what could have changed there. It actually happened for another zone previously though. A restart with that zone closed seemed to fix it.
          I'll try this version and get you the firmware number tonight.
          Tks
            Here's the firmware version
            01.10.118
            I just realized I'm in your HS3 section...sorry.
            I'm still on HS2 while some of the zwave issues get sorted out.
              I moved your posts to another thread.
              Attached is a HS2 version with the same fix. Please try it.
              Also, note that in HS2 you need to refresh the device status page to see the updates.
                Ok I'll give this a try.
                Tks
                Yesterday I had to restart my panel in order to clear a low battery error. It seemed to clear the problem too so wonder if that was the hangup.
                I'll keep an eye on it...
                  Just to let you know I did the upgrade and everything is working fine at the moment. I'll have to watch it the next day or so to confirm if anything has changed. Great plugin though...Gotta keep this going!
                    Got home today and noticed the same issues. I'm reading the log but don't see anything out of the ordinary.
                      so right now you can replicate the problem?
                      if so, what does the log shows when you open and close a zone?
                        That's the weird thing. I open and close a zone and it doesn't update.
                        Here's the log just prior. I opened and closed a zone but the log didn't update. Envisalink site shows the zone closed XX seconds ago.
                        11/8/2013 7:31:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:31:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                        11/8/2013 7:33:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:33:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                        11/8/2013 7:35:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:35:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                        11/8/2013 7:37:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:37:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                        11/8/2013 7:39:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:39:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                        11/8/2013 7:41:00 AM weatherXML Check for any active daily downloads
                        11/8/2013 7:41:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:41:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                        11/8/2013 7:43:05 AM Web Server xxxxxxxxxxxxxxxxxxxxx
                        11/8/2013 7:43:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:45:15 AM EnvisaLink DEBUG Request: Poll
                        11/8/2013 7:45:16 AM EnvisaLink DEBUG CommandAcknowledge 000
                          so if you open a zone and left it opened, the keypad shows it as opened, the local envisalink web page shows it as opened as well, but the plugin is not notified at all?
                          what if you restart HS, does everything get back to normal and work?
                            Yes the restart seems to always fix it.
                              do you use any other program (for example an app on your phone) that use the Envisalink Third Party Interface ?
