No Such Host
  • No Such Host
    I'm trying to setup and test connectivity to my DSC via the Envisalink, and in the log upon startup of HomeSeer, I get the following:
    EnvisaLink ERROR No such host is known
    I've checked and double checked my IP address, password, etc but haven't had any luck. I can connect to the Envisalink direct through my browser with no problem.
    could you set the log level to debug, and post the full log?
    when you connect to the EnvisaLink through your browser do you use the ip address or http://envisalink as the address ?
      I am able to connect both using the ip address in the browser and through the eyezon portal. I have since run the updater and noticed an update for HSPro (2.5 I think...) and the Evisalink plugin. It now appear to connect, but I get a socket eror. Here is the entire log from the last startup.
      11/7/2013 8:15:48 PM ~!~Startup~!~
      11/7/2013 8:15:48 PM ~!~Startup~!~*********************************************** *********************************
      11/7/2013 8:15:48 PM ~!~Startup~!~ HomeSeer version 2.5.0.81 Starting Now (PRO Build)
      11/7/2013 8:15:48 PM ~!~Startup~!~Using system's regional settings
      11/7/2013 8:15:48 PM ~!~Startup~!~Creating Class Objects...
      11/7/2013 8:15:48 PM ~!~Startup~!~COM port classes started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Application interface class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Web server class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~E-Mail SEND class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~E-Mail RECEIVE class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Z-Wave class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Plug-In Interface class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Speech recognition class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~HSPhone dialer class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Loading Settings
      11/7/2013 8:15:48 PM ~!~Startup~!~Settings Loaded.
      11/7/2013 8:15:48 PM ~!~Startup~!~Current sunrise/sunset values calculated.
      11/7/2013 8:15:48 PM ~!~Startup~!~HSPhone external interface class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Local voice recognition class started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Database SAVE process started.
      11/7/2013 8:15:48 PM ~!~Startup~!~Loading configuration file ...
      11/7/2013 8:15:48 PM ~!~System~!~Loading device types file...
      11/7/2013 8:15:48 PM ~!~Database~!~Opening (Mode=Read) up HomeSeer database: C:\Program Files (x86)\HomeSeer HSPRO\config\sample.mdb
      11/7/2013 8:15:48 PM ~!~Database~!~Loading Devices...
      11/7/2013 8:15:48 PM ~!~Load Config~!~14 total devices loaded.
      11/7/2013 8:15:48 PM ~!~Load Config~!~Checking device type settings for all devices...
      11/7/2013 8:15:48 PM ~!~Load Config~!~Finished checking device type settings.
      11/7/2013 8:15:48 PM ~!~Load Config~!~Loading Events...
      11/7/2013 8:15:48 PM ~!~Load Config~!~11 total events loaded.
      11/7/2013 8:15:48 PM ~!~Database~!~HomeSeer configuration database C:\Program Files (x86)\HomeSeer HSPRO\config\sample.mdb has been closed.
      11/7/2013 8:15:48 PM ~!~Startup~!~HomeSeer version is: 2.5.0.81
      11/7/2013 8:15:48 PM ~!~Startup~!~Starting remoting (Remote client connection monitor)
      11/7/2013 8:15:48 PM ~!~Startup~!~Creating Speaker Client Interface Object...
      11/7/2013 8:15:48 PM ~!~Startup~!~Initializing phone interface...
      11/7/2013 8:15:48 PM ~!~HSPhone~!~HomeSeer Phone Web Interface initializing.
      11/7/2013 8:15:48 PM ~!~Startup~!~Checking for pending updates to be installed...
      11/7/2013 8:15:48 PM ~!~Startup~!~Restoring Device Status...
      11/7/2013 8:15:48 PM ~!~Startup~!~Checking for available plug-ins
      11/7/2013 8:15:48 PM ~!~Plug-In~!~Found plug-in: X10 CM11A/CM12U, version: 1.0.1.0
      11/7/2013 8:15:48 PM ~!~Plug-In~!~Found plug-in: X10 CM15AUSB, version: 1.0.0.3
      11/7/2013 8:15:48 PM ~!~Plug-In~!~Found plug-in: DSC Security, version: 2.0.0.14
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: EnvisaLink, version: 1.0.0.6
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: HSTouch Server, version: 1.0.0.72
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: HSTouch Android, version: 1.0.0.2
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: HSTouch iPhone, version: 1.0.0.2
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: Insteon, version: 1.1.52.1
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: iTunes, version: 2.5.0.13
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: Media Player, version: 2.5.0.16
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Found plug-in: UPB, version: 1.0.2.7
      11/7/2013 8:15:55 PM ~!~Startup~!~Initializing Plug-Ins
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Initializing Plug-in: Media Player
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Finished initializing plug-in Media Player
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Initializing Plug-in: HSTouch Android
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Finished initializing plug-in HSTouch Android
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Initializing Plug-in: HSTouch Server
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Finished initializing plug-in HSTouch Server
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Interface EnvisaLink is running as a trial, 30 days remaining.
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Initializing Plug-in: EnvisaLink
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Zone Device Found: Z:4
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Zone Device Found: Z:6
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Zone Device Found: Z:3
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Zone Device Found: Z:2
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Zone Device Found: Z:5
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Zone Device Found: Z:1
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Partition Device Found: P:1
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Finished initializing plug-in EnvisaLink
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Finished initializing X10 interface
      11/7/2013 8:15:55 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:15:55 PM ~!~Plug-In~!~Finished initializing infrared interface
      11/7/2013 8:15:55 PM ~!~Web Server~!~Local IP address (subnet) is: 192.168.183.1 (255.255.255.0)
      11/7/2013 8:15:55 PM ~!~Web Server~!~UPNP Discovery started
      11/7/2013 8:15:55 PM ~!~Web Server~!~Web Server started on port 80
      11/7/2013 8:15:55 PM ~!~Startup~!~Start automation engine...
      11/7/2013 8:15:55 PM ~!~Startup~!~This version of HomeSeer is not registered and is running as a trial, 30 days remaining.
      11/7/2013 8:15:55 PM ~!~Startup~!~Initializing Speaker Client Interface
      11/7/2013 8:15:55 PM ~!~Speech~!~Listening for remote speaker connections on port 8742
      11/7/2013 8:15:55 PM ~!~Startup~!~Starting Event Scheduler...
      11/7/2013 8:15:55 PM ~!~Startup~!~Checking HTTP connection...
      11/7/2013 8:15:55 PM ~!~Web Server~!~Web Server authorized local login successful from: 127.0.0.1 User: default
      11/7/2013 8:15:56 PM ~!~Startup~!~Updater services starting...
      11/7/2013 8:15:56 PM ~!~Startup~!~Starting DDNS service...
      11/7/2013 8:15:56 PM ~!~Startup~!~Running the Startup.txt Script
      11/7/2013 8:15:56 PM ~!~Media Player~!~MPAppThreadProc start
      11/7/2013 8:15:56 PM ~!~Media Player~!~Loading library in the background, this could take a few minutes...
      11/7/2013 8:15:56 PM ~!~Media Player~!~Getting track information...
      11/7/2013 8:15:56 PM ~!~Startup~!~Scripting is OK and is now running Startup.txt
      11/7/2013 8:15:56 PM ~!~Startup~!~HS2Sentry is disabled in Setup, sentry will not be started.
      11/7/2013 8:15:56 PM ~!~Startup~!~Start up complete.
      11/7/2013 8:15:56 PM ~!~Web Server~!~Web Server authorized local login successful from: 192.168.183.1 User: default
      11/7/2013 8:15:56 PM ~!~Startup~!~Creating ASP.NET application host...
      11/7/2013 8:15:56 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:15:56 PM ~!~Startup~!~ASP.NET application host created
      11/7/2013 8:16:01 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:01 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:01 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:02 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:07 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:07 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:07 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:08 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:13 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:13 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:13 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:14 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:17 PM ~!~Network~!~Speaker client connected from: 127.0.0.1
      11/7/2013 8:16:17 PM ~!~Speaker~!~Speaker host added, Name: BOS2LCHARBAUGH IP address: 127.0.0.1
      11/7/2013 8:16:17 PM ~!~Media Player~!~Done getting track information
      11/7/2013 8:16:18 PM ~!~Media Player~!~Warning, queued command did not complete due to timeout: player_state
      11/7/2013 8:16:19 PM ~!~Media Player~!~Warning, could not add voice command for album The First Decade: 1983-1993:Item has already been added. Key in dictionary: 'The First Decade 19831993' Key being added: 'The First Decade 19831993'
      11/7/2013 8:16:19 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:19 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:19 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:20 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:21 PM ~!~Media Player~!~Finished loading Playlists
      11/7/2013 8:16:22 PM ~!~Media Player~!~Library loading completed.
      11/7/2013 8:16:25 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:25 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:25 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:26 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:31 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:31 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:31 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:32 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:37 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:37 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:37 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:38 PM ~!~Media Player~!~Warning, queued command did not complete due to timeout: get_volume
      11/7/2013 8:16:38 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:43 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:43 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:43 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:44 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:49 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:49 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:49 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:50 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:16:55 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:16:55 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:16:55 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:16:56 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:17:01 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:17:01 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:17:01 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:17:02 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:17:07 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:17:07 PM ~!~EnvisaLink~!~ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
      11/7/2013 8:17:07 PM ~!~EnvisaLink~!~DEBUG Stack: at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EnvisaLink.Communications.Reciever.Run()
      11/7/2013 8:17:08 PM ~!~EnvisaLink~!~INFO Trying to reconnect to: 108.72.75.78:4025
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~INFO Reconnection OK
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG Request: NetworkLogin 091606
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG Request: TimeStampControl 1
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG Request: StatusReport
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG Request: Poll
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG LoginInteraction 3
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG CommandAcknowledge 005
      11/7/2013 8:17:13 PM ~!~EnvisaLink~!~DEBUG LoginInteraction 1
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG CommandAcknowledge 055
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG CommandAcknowledge 001
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 001
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 002
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 003
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 004
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 005
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 006
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 007
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 008
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 009
      11/7/2013 8:17:14 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 010
      11/7/2013 8:17:15 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 011
      11/7/2013 8:17:15 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 012
      11/7/2013 8:17:15 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 013
      11/7/2013 8:17:15 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 014
      11/7/2013 8:17:15 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 015
      11/7/2013 8:17:15 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 016
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 017
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 018
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 019
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 020
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 021
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 022
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 023
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 024
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 025
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 026
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 027
      11/7/2013 8:17:16 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 028
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 029
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 030
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 031
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 032
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 033
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 034
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 035
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 036
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 037
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 038
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 039
      11/7/2013 8:17:17 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 040
      11/7/2013 8:17:18 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 041
      11/7/2013 8:17:18 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 042
      11/7/2013 8:17:18 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 043
      11/7/2013 8:17:18 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 044
      11/7/2013 8:17:18 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 045
      11/7/2013 8:17:18 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 046
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 047
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 048
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 049
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 050
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 051
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 052
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 053
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 054
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 055
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 056
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 057
      11/7/2013 8:17:19 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 058
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 059
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 060
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 061
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 062
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 063
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG ZoneRestored 064
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionReady 1
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 2
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 3
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 4
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 5
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 6
      11/7/2013 8:17:20 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 7
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG PartitionisBusy 8
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG TroubleLedoff 1
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG TroubleLedoff 2
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG TroubleLedoff 3
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG TroubleLedoff 4
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG TroubleLedoff 5
      11/7/2013 8:17:21 PM ~!~EnvisaLink~!~DEBUG TroubleLedoff 6
        Do you run another program using the EnvisaLink Third Party interface?
        The envisalink only accepts one client connection at a time.
          I do have an app on my phone...
          Wonder if that is keeping a connection open. Let me try killing that and resetting the envisalink.
            That was it. The app on my phone was holding a connection open.
            Thanks for pointing me in the right direction.
