Problems with .81 on HS2
  • Problems with .81 on HS2
    Hi Spud, it's a long story but the short version is:
    I updated from .52 to .81 a while back because I was having problems with email, so now I'm having problems with a ton of stuff. One of those involves Envisalink.
    It seems to be loosing its connection (see below for a snip of the log from a startup this AM --- I had a ton of these in my log when I got up today) Any ideas what might be causing it.....
    11/10/2013 4:24:32 AM Plug-In Finished initializing plug-in EnvisaLink
    11/10/2013 4:24:32 AM EnvisaLink ERROR A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond XXX.XXX.XXX.XXX:XXXX
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Partition Device Found: P:2
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Partition Device Found: P:1
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:16
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:20
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:15
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:27
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:5
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:6
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:10
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:9
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:11
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:3
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:14
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:19
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:25
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:4
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:23
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:8
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:17
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:22
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:13
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:28
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:24
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:18
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:26
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:21
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:12
    11/10/2013 4:24:11 AM EnvisaLink DEBUG Zone Device Found: Z:7
    11/10/2013 4:24:11 AM Plug-In Initializing Plug-in: EnvisaLink
    Hi,
    This is the kind of error you get when the plugin cannot access the EnvisaLink server. Make sure the ip in the config page is correct, and that you don't have a firewall or AV blocking traffic to this ip.
    Can you access the envisalink local web page from a browser on your HS machine?
      yes I can log in locally
      Yes, I can log in locally, but it looks like HS can't connect, see below for current status. I'm running 1.0.0.6, should I be on a different build?
      PS I can see the board from the EnvisaLink web site also
      PPS when I rebooted HS it connected - not sure what is going on - sigh
        1.0.0.6 is fine
        so after reboot of HS it works?
        if you still get problems you can try to reboot the EnvisaLink board from web page.
        and if the problem still occurs, try to open a telnet session with EnvisaLink TPI. The EnvisaLink TPI server listen on port 4025, so the command is:
        telnet <envisalink_ip> 4025
        if everything ok, it should answer with the message: 5053CD
          OK, thanks...
          OK, and I'll leave debug on and see if it catches anything, right now it seems to be fine. The problem is very random
          It is likely on the HS side - ever since I updated from .52 to .81 I have been having one problem after the next.
            Debug error capture
            This was in my log, not sure it is important but wondering what caused it?
            11/11/2013 3:52:26 PM EnvisaLink DEBUG CommandAcknowledge 000
            11/11/2013 3:52:25 PM EnvisaLink INFO Reconnection OK
            11/11/2013 3:52:25 PM EnvisaLink DEBUG Stack: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at EnvisaLink.Communications.TpiResponse.Parse(String data) at EnvisaLink.Communications.Reciever.Run() at EnvisaLink.Communications.Communicator.ListenForData()
            11/11/2013 3:52:25 PM EnvisaLink ERROR Index and length must refer to a location within the string.Parameter name: length
            11/11/2013 3:52:25 PM EnvisaLink DEBUG PartitionReadyForceArmingEnabled 1
            11/11/2013 3:52:25 PM EnvisaLink DEBUG Request: Poll
            11/11/2013 3:51:48 PM Event Event Trigger "NetCam camera motion test"
            11/11/2013 3:50:26 PM EnvisaLink DEBUG CommandAcknowledge 000
            11/11/2013 3:50:25 PM EnvisaLink DEBUG Request: Poll
            11/11/2013 3:48:26 PM EnvisaLink DEBUG CommandAcknowledge 000
              It means the plugin failed to parse one message, unfortunately plugin didn't log the data sent.
              Please install v1.0.0.8 which log more stuff, and post your logs again if this happens again.
              v1.0.0.8 is available here:
              http://board.homeseer.com/showthread...85#post1067585
                OK, thx
                OK, up on v1.0.0.8 - I'll let you know if I see it again....
