HS Touch shows zones like door but not partition
  • HS Touch shows zones like door but not partition
    I can see the doors in HS Touch/Devices.
    But not the partition itself.
    Also read about the sync time feature but could not find it.
    Still learning HS3.
    Weird, I can see the partition device in HSTouch just fine.
    Still learning HS3.
    The sync time feature is implemented as an action you can run from an event. Create an event then select "EnvisaLink Sends Command" as the action, then select "Sync Alarm Time" as the action type.
