Here is a little script that will change the Partition device text string from "Not Ready"
to "Open zones: Entry door, main-room window left".
This is also great for HSTouch:
Install:
Copy the attached script in your /script directory.
rename it to "Envisalink_string_update.vb" by removing ".txt" (or use any other name with .vb)
Trigger in an event:
IF EnvisaLink Receives Message: Zone Open
Zone = Any
OR IF EnvisaLink Receives Message: Zone Restored
Zone = Any
You can also set the script to update either the Envisalink Partition device, or another device. See instructions by editing the script.
I still think this could be a nice native feature for Envisalink plugin, you may ask Spud the same if you like it...
Install:
Zone = Any
Zone = Any
