Initial DSC setup and Envisalink
  • #16
    Originally posted by 519zwave View Post
    I Don't use it as alarm and many zones should show open as not connected. I'd guess that to be a problem except that 9-16 added fine. ALL zones present on Envisalink website - BUT they are all listed as CLOSED and most are not.
    All zones show properly done on DSC and expanders are listed here:
    2015-12-13 15:57:53 - PC5400 Supervisory Restore
    2015-12-13 15:57:52 - Zone Expander 5 Supervisory Restoral
    2015-12-13 15:57:52 - Zone Expander 4 Supervisory Restoral
    2015-12-13 15:57:51 - Zone Expander 3 Supervisory Restoral
    2015-12-13 15:57:51 - Zone Expander 2 Supervisory Restoral
    2015-12-13 15:57:50 - Zone Expander 1 Supervisory Restoral
    Does Envisalink need additional programming to add more than 16 zones?
    not that I know of...
    • #17
      Originally posted by spud View Post
      I encourage other users to comment on this, but from my experience the communication from the panel to HS3 through EnvisaLink is instant for me.
      For me, PIR latency is the issue. It can take from 1 to 4 seconds before the sensor picks up; this may be a PIR setting issue or a bad PIR.
      • #18
        That is exactly my concern. I have tried Bosch and DSC PIRs and they all seem to have about a 1 second lag reporting motion, which is still acceptable for motion controlled lighting. Using the Arduino as the input device and a Z-Wave switch or dimmer as the light control yields a response almost immediately after the PIR reports motion. The Arduino input triggers an event nearly instantly, so the only delays are in the PIR itself and the Z-Wave communication. As long as there is little or no added delay in going through the panel, Envisalink module and plug-in it would be fine.
        Delays in motion controlled lighting are a deal breaker for WAF around here.
        Randy Prade
        Aurora, CO
        Prades.net
        • #19
          I'm not an expert on PIR's, but in my previous house I installed Paradox equipment with DG50 PIR's and you couldn't move 2-3 feet before the sensor would detect. Our current house (resale) had a DSC system with Paradox NV5 PIR's which are supposed to be so much more responsive. But they're not. I believe on the other hand that these NV5's are adjustable (slow/fast response) and perhaps they're not set properly.
          The point is, PIR's will perform in part based on how they're set up.
          • #20
            Thanks Spud -fixed issue - was my fault - My DSC auto registered zones 9-16, but I had to turn 17-48 on in programming 204-207. Sorry about that.
            Your plug-in continues to work great for me.
            Jim
            Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
            Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
            • #21
              I received my panel and put it in for a test over the holiday. It felt a little slower than my Arduino on the motion sensors, so I set up a handful of events to test it. I installed and configured the panel with a handful of PIRs and wired a couple of them to the panel as well as an Arduino input.
              The events restart a pair of timers when the device goes to motion as well as to write a log entry with the other timer in it. I get a pair of log entries: the event that triggers first will show the other timer at 0:00:00 and the second event to trigger will show the elapsed time since the first. I ran the events for the last couple of days. Below is a sampling of the log entries, I edited out the first triggers, so all that is left is the second.
              Dec-27 9:31:59 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.6406368
              Dec-27 9:31:49 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5937520
              Dec-27 9:30:48 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5469339
              Dec-27 9:29:45 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.1562386
              Dec-27 9:28:05 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6406274
              Dec-27 9:27:04 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.4687690
              Dec-27 9:24:50 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.7499332
              Dec-27 9:23:46 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5468769
              Dec-27 9:23:36 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4062506
              Dec-27 9:22:36 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.4999993
              Dec-27 9:21:44 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5156243
              Dec-27 9:20:41 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.7031369
              Dec-27 9:19:40 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4687501
              Dec-27 9:18:45 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6406407
              Dec-27 9:13:19 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6250141
              Dec-27 9:11:24 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6093034
              Dec-27 9:07:51 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.7656290
              Dec-27 9:07:43 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.7187483
              Dec-27 9:06:43 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4218746
              Dec-27 9:05:39 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.7187471
              Dec-27 9:05:22 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.7031356
              Dec-27 8:58:57 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.8906136
              Dec-27 8:57:55 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.4843816
              Dec-27 8:56:31 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5312006
              Dec-27 8:55:46 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.3593692
              Dec-27 8:55:12 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5312589
              Dec-27 8:54:22 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5625018
              Dec-27 8:53:20 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5000129
              Dec-27 8:52:16 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5937985
              Dec-27 8:32:41 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.7656386
              Dec-27 8:26:45 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4531344
              Dec-27 8:25:21 AM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4843754
              Dec-27 12:52:57 AM Trigger DSC Motion EX - Arduino Timer: 00:00:00.7812454
              Dec-26 11:55:08 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.3125090
              Dec-26 11:53:05 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5937535
              Dec-26 11:51:44 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.3124987
              Dec-26 11:21:12 PM Trigger Arduino Motion DSB - DSC Timer: 00:00:00.3281191
              Dec-26 11:20:39 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.3593627
              Dec-26 11:18:42 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5000036
              Dec-26 11:15:19 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.3593745
              Dec-26 11:11:24 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5624898
              Dec-26 9:59:47 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.5468737
              Dec-26 9:58:50 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4687488
              Dec-26 9:57:48 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.4062542
              Dec-26 9:54:35 PM Trigger Arduino Motion DSB - DSC Timer: 00:00:00.8906197
              Dec-26 9:52:44 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.6562500
              Dec-26 9:52:34 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.4062391
              Dec-26 9:45:54 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.8281254
              Dec-26 9:45:26 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.3750048
              This is just a sample, but the results have been very consistent, the Envisalink is around 1/2-3/4 second behind the Arduino and earlier tests show the Arduino to be about 1/2 second behind the PIR.
              The net result is that the Envisalink is *slightly* slower than the Arduino, but not much.
              When it comes to triggering a light with motion, it is amazing how sensitive we are to delays. The 1/2 second additional, *feels* longer.
              Randy Prade
              Aurora, CO
              Prades.net
              • #22
                what type of trigger did you use: the native "device changes and become" type or the "EnvisaLink receives a message: Zone open" type?
                I wonder if there is a significant timing difference between the two?
                • #23
                  I used the device. I can test the message just for the heck of it. I believed the device would be quicker.
                  To everyone clear the delays are almost insignificant.
                  Randy Prade
                  Aurora, CO
                  Prades.net
                  • #24
                    Here is a set of log entries after I set up secondary events using the "zone open" trigger. They are tagged with DSCM the device based triggers are just "DSC". As you can see the trigger time in all but three cases is identical. In all but one the three that weren't, the difference was insignificant. That would be consistent with what I would have expected. In my system, HomeSeer processes events instantly in all cases. I have never been able to catch any delays created within the core program. The Z-Wave plug-in is another story...
                    Dec-27 7:13:49 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.4687876
                    Dec-27 7:13:49 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.4687876
                    Dec-27 7:12:47 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.2656136
                    Dec-27 7:12:47 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.2656136
                    Dec-27 7:11:36 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6718741
                    Dec-27 7:11:36 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.6718741
                    Dec-27 7:10:38 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5625041
                    Dec-27 7:10:38 PM Trigger DSCM Motion DSB - Arduino Timer: 00:00:00.5625041
                    Dec-27 4:59:31 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.1718857
                    Dec-27 4:59:31 PM Trigger DSCM Motion DSB - Arduino Timer: 00:00:00.1718857
                    Dec-27 4:58:45 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.7656324
                    Dec-27 4:58:45 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.7500114
                    Dec-27 4:53:27 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.3749902
                    Dec-27 4:53:27 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.3749902
                    Dec-27 3:50:02 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.6562096
                    Dec-27 3:50:02 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6405728
                    Dec-27 3:49:30 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.5780605
                    Dec-27 3:49:30 PM Trigger DSCM Motion DSB - Arduino Timer: 00:00:00.5780605
                    Dec-27 3:48:20 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.6562546
                    Dec-27 3:48:20 PM Trigger DSCM Motion DSB - Arduino Timer: 00:00:00.6562546
                    Dec-27 3:47:19 PM Trigger DSC Motion DSB - Arduino Timer: 00:00:00.7499968
                    Dec-27 3:47:19 PM Trigger DSCM Motion DSB - Arduino Timer: 00:00:00.7499968
                    Dec-27 3:46:43 PM Trigger DSCM Motion EX - Arduino Timer: 00:00:00.8437484
                    Dec-27 3:46:43 PM Trigger DSC Motion EX - Arduino Timer: 00:00:00.6874986
                    Based on these tests, I would say it is safe to assume one trigger is as good as another. In the cases where there was a difference, the device was faster.
                    Randy Prade
                    Aurora, CO
                    Prades.net
                    • #25
                      Randy, so is it fair to conclude that you're pretty happy with the way you're getting motion reports from the Enivsalink -- I.e., insignificant delays?
                      • #26
                        Yes. Though there is a slight additional delay added, it is so slight it really doesn't matter. Every PIR I have tested has about a second of response lag. The inexpensive DSC sensors I am using are as fast as any I tested. With an Arduino as the interface there is about a second and a half for a light to come on when the room is entered. With the Envisalink it is about two seconds.
                        The one room that is most tested is a room in the basement. The fastest response we ever had was with the old HSM100 Z-Wave PIR. The Aeotec sensors were slower. Subjectively (I don't know how to measure) I would say that the Envisalink trigger is faster than the Aeotec sensor and slower than the HSM100s. My wife says the Envisalink response is quick enough for her. If it is responsive enough for her entering with a basket of laundry, it is fast enough.
                        Randy Prade
                        Aurora, CO
                        Prades.net
