Programming the DSC with envisalink
  • #16
    Originally posted by hoffsta View Post
    I just bought a PC1864 board with Envisalink 4 and I want to program it using the DLS software. If I built the cable you describe above, I would not need to buy the PC-Link adapter, is that correct?
    Correct.
    So I would build the cable, add a Serial to USB adapter to plug into my laptop, and then run the DLS software. Someone mentioned needing a keypad to enter the programming mode. Is it possible to send the needed commands to enter programming mode from the Envisalink or will I need to buy a keypad as well? Thanks!
    I believe you can send keypad commands with the different DSC plugins, so that should be doable.
    Cheers
    Al
    • #17
      Get a keypad!
      Send keys are included in the TPI, however, it has very limited strings and you need to tie sequences together. The send keys mimics commands as sent by a keypad entry but you'll have no visibility or feedback.
      For quick and easy access and even quick programming a keypad is advisable.
