Questions from someone new to security panels
Originally posted by sparkman View PostNP. I thought the DLS software was backwards compatible. I may have a copy of 2002 somewhere if it doesn't work.
Cheers
Al
Originally posted by tamu View PostI'm currently setup with a DSC PC1616 v4.1 board. I also have a PC5950 two way audio board. It took us a while to get the PC5950 setup via the keypad a couple of years back.
I'm about to swap out the PC1616 with an 1832 v4.6. I have the serial adapter/cable, just need to get the DLS software somewhere. My question is...how easy is it to do a panel swap with the software? I read you can do a config backup of the board, I just don't know if a restore to a brand new panel is supported.
Cheers
Al
Originally posted by bdraper View PostNo problem, glad to help. I think you will find programming the panel with the software to be a much easier task. I programmed some of my DSC panel with the keypad, and I quickly looked for an alternative. If I installed these panels everyday, then it would probably be second nature...
On the external panel, good idea. Thanks
Holy crap is that expensive! I'm paying $48/month for a full-blown Alarm.com setup with Guardian.
I'm going to be replacing that with a DSC system. I have a router that fails over from cablemodem to LTE already (Cradlepoint), and I pay AT&T $20/month for the LTE. So I figured I'll do alarm monitoring over IP.
Since I"ll be buying the EnvisaLink anyway, I figured I'll go with their EnvisAlarms service, $9/month.
I just want bare bone alarm monitoring, and do all the other stuff I was doing with alarm.com through HS.
Originally posted by cheeryfool View PostTom
Thanks for this. Yes, I am out of contract and just checked the current monthly - $67 &%*%$! I am sure I could get that down to under $50 with negotiation AND signing a new contract, but that's still robbery and I am over it.
Unfortunately, my panel is a GE Concord Express, which has no means of integration to HS, unlike the GE Concord 4 and most panels from Honeywell, DSC etc. Yes, I believe it will work with AlarmRelay's device, but I really want integration with HS, so I need to look at something new. Hoping that I will be able to re-use some sensors and some wiring.
I also, really want wired motion sensors throughout the house, which will be a bit of work, but 6 years in (and about 2,500' of LV cabling), I have figured out concealed routes to virtually every location. I only have 2 free wired zones remaining on the existing panel also.
Cheers
James
Originally posted by TomTom View PostCheeryfool, I assume you leave adt when you finish the contract? It's pretty hard here to get out of security company contracts . If you're out of contract just use your adt panel. They are usually ademco/Honeywell >> dsc. If you want easy guide way to reprogram the panel just call alarmrelay sign up for their 1 yrs service, $9/mo, and they will walk you through over the phone on how to reprogram your existing panel.
Sent from my iPhone
Cheers
James
Sent from my iPhone
I have been following this thread with interest as I have been contemplating for a long time ditching my expensive ADT contract and my current panel cannot be 'integrated' - GE/ITI Concord Express.
One of the core things that I am interested in is wired combo CO/Smoke detectors and also wired motions. A recessed ceiling triple-play would be a killer device, especially if it had PIR and microwave motion sensing.
Back to (somewhat) reality. Nest had an alarm panel enabled smoke detector for a while, but that seems to have been part of the Nest Protect recall and that has not been re-launched with the current v2 Protect. This might seem a bit backwards, but what hardware would be needed to trigger a zone on a DSC panel from the Nest device in HS3 (I am using Spud's Nest PI) An Arduino or some simpler type of relay?
It's just a thought and I've read all the cautions about mixing HA and Fire/Security systems.
Anyway, just a random Monday thought
Originally posted by bdraper View PostDoes anyone have any pictures of a panel with multiple zone expansion modules? I am trying to figure out how to position the modules in the cabinet. Mine is quite full with the main board, battery, IT-100. Does everyone just get an additional cabinet?
Originally posted by rprade View PostThanks for your software pictures, that helps a lot. I will be getting the serial cable with my panel and have downloaded the software.
With regard to expansion boards, it is my understanding that the standard cabinet will accommodate an expansion board on each side of the main board. They are mounted to the side of the cabinets. For my installation it makes more sense to mount the expansion boards remotely to save on wiring. I will probably only mount the Envisalink interface in the main cabinet.
