New error for Envisalink
  • New error for Envisalink
    SOLVED - IP CONFLICT error on my end.
    Hi Spud,
    This error started happening last night and envisalink won't connect. Any suggestions?
    Dec-29 8:14:47 AM EnvisaLink INFO Trying to reconnect to: 192.168.1.142:4025 Dec-29 8:13:47 AM EnvisaLink ERROR No connection could be made because the target machine actively refused it 192.168.1.142:4025
    Jim
    Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
    Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
    do you get the same error if you restart the plugin?
    can you access the local web page: http://envisalink ?
    if so you can try to reboot the Envisalink board from the network page.
      No luck.
      Rebooted plugin, router, hs3 - EVERYTHING
      Got this error from envisalink site:
      ERROR: Duplicate IP address detected on the network
      (UPDATE: that error no longer on envisalink site - all seems good there, but error still with plugin.)
      Checked router - no duplicates anywhere.
      Have logged a help request there...
      Jim
        The plugin always says duplicate IP for me as well, even though that is not the case.
        I have my own Windows DHCP servers and the IP is definitely not being leased by anything other than the Envisalink.
          Solved this problem
          SO: Power went out last night - another device stole the IP address for Envisalink as I guess it booted up first. Was hidden in DHCP and couldn't see conflict. AND for some reason I can't lock my Envisalink via DHCP so let's hope a UPS solves this!
          Jim
            And as an FYI
            EyezON was back to me with support within an hour - quite impressive!
            Jim
