Multiple Envisalink Connections
  • Multiple Envisalink Connections
    Does the Envisalink Plug In support two DSC Panel connections?
    I want to put a separate DSC panel in my outbuilding and monitor both it and my home DSC using the same HS3.
    Thanks!
    no it doesn't, but I could easily modify it so that it supports multi instance, then you will just need to start a second instance of the plugin to connect to your second panel.
    let me know if you want me to do it
      Thanks Spud.
      Am I the first one to request this? It seems like it would be a common request for home owners with multiple buildings. I would prefer to add to my house DSC but just too far for running all the wires.
      If you added this would it become part of the standard Plugin or a special version?
        Have you considered a remote expansion board? How many zones do you need in your outbuilding? This is what is typically done for outbuildings such as shops.
        Cheers
        Al
          Originally posted by Beairmo View Post
          Thanks Spud.
          yes you are the first to request this feature, as Al said using extension boards and different partitions is a more typical solution.
          if I added the multi instance feature, it would become part of the standard plugin.
