causing HS to send callbacks
  • causing HS to send callbacks
    Hi,
    Few days ago I started to use BLRadar plugin to collect last echo info from my motion sensors connected to Envisalink plugin. The last echo data that I get is far off sync from what I should get. Is Envisalink plugin set the device value for the DSC devices causing HS to send callbacks?
    Best regards,
    hadyos
    Originally posted by hadyos View Post
    Hi,
    Best regards,
    hadyos
    I'm not sure I understand the problem and I have no experience with BLRadar, but if it relies on device last change time, maybe you can try to check the "Do not update device last change time if device value does not change:" checkbox in your zone devices configuration.
    If that's not the problem then please provide more information, thanks.
      I Wrote to BLRadar developer and he says that it relies on HomeSeer making a callback into BLRadar when the value changes for the device.
