Email user status
    Email user status
    Hi
    Great plugin - just switching everything over and trying to simply all the scripts I had which aren't necessary with this. One I can't work out is emailing the user status. The help says something like this in the email subject area of the event:
    $$DSUser Access) at $date $time
    but I can't find the right syntax to make it accept the User Access variable. The help only describes this being an address, and it doesn't seem to like the address "User Access".
    according to this: http://homeseer.com/support/homeseer..._variables.htm
    I don't think you can get the device status using its name. I would recommend to use the device reference number which is basically it's id:
    $$DSR:1234:
    where 1234 is the reference id of the device that you can see from the Advanced tab when you edit a device.Don't forget the colon at the end.
      Thanks! Knew it would be simple. That worked immediately!
