I'm wondering if this is such a new version that anyone has tested it with HS3 as well?
EnvisaLink Trigger on Zone Open doesn't work....
I don't think the problem is the EnvisaLink firmware, a lot of users are successfully running the HS3 plugin with a EVL4
I would need to fire my old HS2 install to debug (which I' m a bit reluctant to). Since the devices are correctly updating can' t you use that to triggers your events instead of using the specific EnvisaLink triggers?
Well something happened which I hope provides a clue.
I changed the event to "Device Status Change"
In the "Status:" dropdown, there is just one that works and that is "Set Any Status" But it fires when the zone opens and closes. I tried "Set On" and no luck.
Also even if that worked there doesn't appear to be a way to trap:
Alarm Armed Away
Alarm Armed Stay
AC Panel Fualt
TLM Fault
and about a half dozen other DSC events that I use that don't seem to have corresponding devices analogs.
