Closed/Opened icons missing ?
  • Closed/Opened icons missing ?
    The Closed/Opened icons are missing in
    "HomeSeer HS3\html\images\EnvisaLink"
    There is only the envisalink.png.
    I tried to reinstall the plugin, but same results. Where should these icons come from?
    In version 3.0.0.29 and later, the icons used are the default HS icons located in html/images/HomeSeer/status/
    if your devices were created with an older version they would still use the old icons in html/images/EnvisaLink installed by the old version installer. So the icons should still be there unless you deleted them manually.
    anyway, old icons are attached to this post if you want them.
      My issue stems from a mixture of old and new: devices created early on, reinstall after a crash. All ok now, thanks.
