Does anyone know which location changes I need to make to get the PC to talk with the alarm panel (NX8E) using the DL900 software?
I have some programming changes to make and I have always just used the keypad but would like to try the software. The DL900 will not talk to the panel with the same settings that are used for HS.
At least thats what I'm guessing it is. Plugin works great.
Hoping its just a simple location change that I can move back and forth when I want to program or run the plugin.
Also if there was a plug in pause to allow the DL900 programming w/o shutting down HS that would be great. Kinda like the one used for the UPB.
-Tim
-Tim
