I have an event setup to bypass the motion detector in a room when the z-wave lock of the front door is engaged. This generally means that the panel has been armed, I exited through this door and engaged the lock. We keep our cat in that room and it has a tendency to trip the motion. This works. I also have the opposite event setup which is when the front door is unlocked that motion/zone is set to unbypass. That doesn't work. I can see in the event log that the event triggers buty the zone doesn't go back to normal.
I've solved this by setting up two different events one to bypass the zone when the panel arms and one to unbypass the zone when the panel disarms. I'm just curious as to why my unbypass event is failing under the first scenario.
Paul
Paul
