Advice on programming zone names with DL900
    I have noticed that when the plugin reads some zone names it is pulling in the default name of the zone - "Zone 16" for example. When I look in DL900 I see that the zone is named more descriptively - the way I originally named it - "living room motion" for example. When I perform a read section in DL900 it still shows. If I select read all in DL900 then it resets back to "Zone 16". So i correct it and perform a send Section. Repeat the process above and it resets back to "Zone 16". So clearly I am not storing this information correctly in the panel. At advice on how to get the name to stick in the panel? Thanks.
