MYQ interface error
    MYQ interface error
    Hi,
    can anyone help me with the error's i am getting on the myq interface.
    here are my logs:
    1. WARNING: Failed getting InterfaceStatus from MyQ - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    2.
    Initializing plug-in(2): MyQ Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    3.
    2017-12-05 21:29:45 | INFO | Plugin: MyQ Instance: starting...
    2017-12-05 21:29:45 | INFO | Connecting to server at 127.0.0.1...
    2017-12-05 21:29:45 | INFO | Host API Version: 3
    2017-12-05 21:29:45 | INFO | Connected, initializing plugin...
    2017-12-05 21:29:45 | DEBUG | Loglevel set to: Debug
    2017-12-05 21:29:45 | INFO | Initializing version 1.1.17336.309
    2017-12-05 21:29:45 | DEBUG | Enabled logging to HomeSeer log system
    2017-12-05 21:29:46 | DEBUG | Reconfigured remote logging destinations
    2017-12-05 21:29:47 | FATAL | Exception int InitIO: Port:{port}
    KJ
    Originally posted by kjp View Post
    Hi,
    here are my logs:
    2.
    3.
    KJ
    I see what's happening. I'll get a fix out ASAP, but I'm down with the flu right now. In the meantime if you need to be up and running you can go into the myq.ini file in the config directory and disable the remote logging option.
      Thanks for reply and the temp fix.....
      KJ
        KJ
        New version posted should have a permanent fix
