Can we get the safety sensors as HS3 devices
  • Can we get the safety sensors as HS3 devices
    Can we get the safety sensors as HS3 devices.
    I'm not sure what you mean. Is this a separate device or part of the garage door opener? If it's part of the opener, there is no indication of the safety sensor in the data that the web service provides. If it's a different device, I'd have to go buy one and reverse engineer the communications to figure out what can be done.
      The safety sensor is an integral part of the garage door opener. Comes with the garage door opener. These are the photoelectric sensors that are attached to the bottom of the door frame to prevent the door from smashing into an object left in its way.
      They are wired to the main unit of the garage door opener.
      The door re-openes automatically if something gets in the way during closure.
      The door will not start closing if something is already in the way.
      So the main unit must "know" the status of the safety sensor.
        ok. The web service does not report the status out the sensor in any way, so there is nothing for me to be able to report. The web service sends back a JSON file with several variables in it. If you would like I can post a sample file here for you to see what is available. However none of the variables indicate the status of the sensor.
          Originally posted by kingfetty View Post
          ok. The web service sends back a JSON file with several variables in it. If you would like I can post a sample file here .
          Please do. Some nifty ideas may come out of it.
            Here's a dump of my JSON data. Obviously I XXXX out my email address and some other things.
            	"Devices": [{
            		"MyQDeviceId": 572211,
            		"MyQDeviceTypeId": 1,
            		"MyQDeviceTypeName": "Gateway",
            		"RegistrationDateTime": "2018-03-03T22:56:19.424435Z",
            		"SerialNumber": "xxxxxxxxxxxx",
            		"UserName": "xxxxxxxxxxxxxx",
            		"UserCountryId": 0,
            		"Attributes": [{
            			"MyQDeviceTypeAttributeId": 135,
            			"Value": "True",
            			"UpdatedTime": "1520117779424",
            			"IsDeviceProperty": false,
            			"AttributeDisplayName": "online",
            			"IsPersistent": false,
            			"IsTimeSeries": false,
            			"IsGlobal": false,
            			"UpdatedDate": "2018-03-03T22:56:19.424435Z"
            			"MyQDeviceTypeAttributeId": 1,
            			"Value": "0",
            			"AttributeDisplayName": "enumeraterequired",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 3,
            			"Value": "0",
            			"AttributeDisplayName": "learnmodestate",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 6,
            			"Value": "2018-03-03 22:56:19",
            			"AttributeDisplayName": "addedtime",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 25,
            			"Value": "572213,572215",
            			"AttributeDisplayName": "devices",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 26,
            			"Value": "2",
            			"AttributeDisplayName": "numdevices",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 28,
            			"Value": "Home",
            			"AttributeDisplayName": "desc",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 33,
            			"Value": "4.2",
            			"AttributeDisplayName": "fwver",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 95,
            			"Value": "GW0100032E1D",
            			"AttributeDisplayName": "name",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 104,
            			"AttributeDisplayName": "deviceName",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 4,
            			"AttributeDisplayName": "customerName",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 438,
            			"Value": "False",
            			"AttributeDisplayName": "ishomekitcapable",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 439,
            			"Value": "False",
            			"AttributeDisplayName": "ishomekitactive",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 440,
            			"Value": "True",
            			"AttributeDisplayName": "IsFirmwareCurrent",
            			"IsGlobal": false,
            		"ChildrenMyQDeviceIds": "572213,572215",
            		"UpdatedBy": "System",
            		"UpdatedDate": "2018-03-03T22:56:19.424435Z",
            		"ConnectServerDeviceId": "572211"
            		"MyQDeviceId": 572213,
            		"ParentMyQDeviceId": 572211,
            		"MyQDeviceTypeId": 2,
            		"MyQDeviceTypeName": "GarageDoorOpener",
            		"RegistrationDateTime": "2018-03-03T15:21:49.324899Z",
            		"SerialNumber": "XXXXXX",
            		"UserName": "XXXXXX",
            		"UserCountryId": 0,
            		"Attributes": [{
            			"Value": "True",
            			"UpdatedTime": "1520090509325",
            			"IsGlobal": false,
            			"UpdatedDate": "2018-03-03T15:21:49.324899Z"
            			"MyQDeviceTypeAttributeId": 49,
            			"Value": "572211",
            			"AttributeDisplayName": "gatewayID",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 50,
            			"Value": "Left Garage Door",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 56,
            			"Value": "2",
            			"AttributeDisplayName": "doorstate",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 61,
            			"Value": "1520090509325",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 77,
            			"Value": "1",
            			"AttributeDisplayName": "isunattendedopenallowed",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 78,
            			"Value": "1",
            			"AttributeDisplayName": "isunattendedcloseallowed",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 87,
            			"Value": "XXXXXX",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 75,
            			"Value": "XXXXXX",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 699,
            			"Value": "False",
            			"AttributeDisplayName": "is_gdo_lock_connected",
            			"IsGlobal": false,
            			"MyQDeviceTypeAttributeId": 799,
            			"Value": "False",
            			"AttributeDisplayName": "attached_work_light_error_present",
            			"IsGlobal": false,
            		"ChildrenMyQDeviceIds": "",
            		"UpdatedDate": "2018-03-03T15:21:49.324899Z",
            		"ConnectServerDeviceId": "572213"
            		"MyQDeviceId": 572215,
            		"RegistrationDateTime": "2018-03-03T22:46:18.3602123Z",
            		"UserCountryId": 0,
            		"Attributes": [{
            			"Value": "True",
            			"UpdatedTime": "1520117178360",
            			"IsGlobal": false,
            			"UpdatedDate": "2018-03-03T22:46:18.3602123Z"
            			"Value": "572211",
            			"IsGlobal": false,
            			"Value": "Right Garage Door",
            			"IsGlobal": false,
            			"Value": "1",
            			"IsGlobal": false,
            			"Value": "1520117178360",
            			"IsGlobal": false,
            			"Value": "1",
            			"IsGlobal": false,
            			"Value": "1",
            			"IsGlobal": false,
            			"Value": "XXXXXX",
            			"IsGlobal": false,
            			"Value": "XXXXXX",
            			"IsGlobal": false,
            			"Value": "False",
            			"IsGlobal": false,
            			"Value": "False",
            			"IsGlobal": false,
            		"UpdatedDate": "2018-03-03T22:46:18.3602123Z",
            		"ConnectServerDeviceId": "572215"
            	"ReturnCode": "0",
            	"ErrorMessage": "",
            	"CorrelationId": "XXXXXXXXXXXXX"
              Thanks.
