Updated now not working
  • Updated now not working
    Hello,
    I just updated the myq plugin the other day and now I getting an error when turning on the plugin,
    WARNING: Failed getting InterfaceStatus from MyQ - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    Also seeing this in syslog:
    System.TypeInitializationException: The type initializer for 'HSPI_MyQ.Program' threw an exception. ---> NLog.NLogConfigurationException: Error when setting property 'Format' on Layout Renderer: ${date} ---> System.ArgumentException: Object of type 'System.ReadOnlySpan`1[System.Char]' cannot be converted to type 'System.String'.
    Apr 18 21:33:31 ult4dr-Unix mono[14496]: at System.RuntimeType.CheckValue (System.Object value, System.Reflection.Binder binder, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00071] in <9bbab8f8a2a246e98480e70b0839fd67>:0
    Originally posted by ult4dr View Post
    Hello,
    Based on this dump it's linux OS?
    What was the old version you were running?
    There is a known issue with the latest version of MONO and the NLog 3rd party DLL I use. What version of MONO are you running?
      Mono JIT compiler version 5.10.1.47 (tarball Tue Apr 17 15:12:35 UTC 2018)
      TLS: __thread
      SIGSEGV: altstack
      Notifications: epoll
      Architecture: amd64
      Disabled: none
      Misc: softdebug
      Interpreter: yes
      LLVM: supported, not enabled.
      GC: sgen (concurrent by default)
        TLS: __thread
        SIGSEGV: altstack
        Architecture: amd64
        Disabled: none
        Misc: softdebug
        Interpreter: yes
        Yeah, it's confirmed that 5.10.X breaks the NLog DLL that I use for logging. I've been looking for a fix and workaround for this. I may end up stripping out the logging feature. If you want you can either roll the Mono back to a previous release or just await a fix from me.
          For additional information, I am currently testing some builds that show promise.
            Try build .312 of the plugin (just uploaded) and see if that helps any.
              Wonderful I will try that. Thank you for your support.
              I will let you know.
                All good. It works again.
                Thank you!
