My Q plug in Still not loading
    I been trying to get the MYQ plug in working on my system and i wont load, Been trying for a couple days and i get the same thing ( WARNING : Failed getting InterfaceStatus from MYQ. The Interface was not found in the active Interface. do I need to load an interface or something? and how would i go about that?
    Are you running Linux or Windows? What version of .Net framework is installed if windows? If Linux, what version of Mono?
      Hello I'm running windows and net .framework is 4.5
        .net framework 4.6 or greater is required.
          Thank you for that info, my computer has .net Framework 4.7.2 and gives me the same info
            So you're unable to start the plugin on your computer either?
              yes will not start sir
                Has it ever worked?
                  no never
                    Is there something that i can do to make this work?
                      You can try to reinstall .net framework 4.7
                      You could wipe out any existing settings by going into "c:\Program Files (x86)\HomeSeer HS3\Config" and deleting the MyQ.ini file
                      Also completely wipe out the existing plugin by deleting the following 2 files in "\c:\Program Files (x86)\HomeSeer HS3"
                      MyQ.exe
                      MyQ.exe.conf
                      You could try reinstalling HomeSeer and see if that helps also
                      Other than that, I'm not sure what could be wrong with your PC that's stopping this from launching.
