My Q interface
  • My Q interface
    Still working on the MYQ plug in trying to get in to run on my system. do i need a home bridge to make this plug in work? It's telling me the interface did not load.
    You will need a MyQ enabled garage door and the account setup with MyQ so that the app on you cell phone works to open/close the door. Once that is done, you should be able to put the mobile app credentials into the plugin and it will mimic the app behavior.
      Hello The MYQ Plug in will not let me do anything . just get the warning can not get the interface to MYQ?
        That error indicates the plugin is not even starting. Biggest reason for failure to launch is that the latest version of the .net framework is not installed.
        -edit-
        .net framework 4.6 or greater is needed.
