MYQ NEW INSTALL NOT WORKING
  • MYQ NEW INSTALL NOT WORKING
    i just installed MYQ and i can not get it to work this is the log entry
    You have no services enabled, please goto the MyQ plugin settings and configure a service and enable the checkbox.
    each time i open the configured screen the check is missing and i have tried at least 20 times
    what do i do next? there is no sign of the plug in has been installed except in plug in areas
    Did you setup the correct username and password, and then check the correct service checkbox? It will uncheck the service check box if it tries to login too many times and gets an authentication failed every time.
      I used the same login information as i do in the MYQ app one thing that i found out is that my opener is a commercial unit. does that mater? if so what type of information do i need?
