Communication problem
  • Communication problem
    Having an odd problem with MyQ. Plugin installed fine and credentials are good, I can open and close the door from Homeseer. I can’t seem to get information back from the garage door opener. For example when the door is opening I want to turn on a light. However the event doesn’t trigger. If I manual push play on my event, it works fine. But when using the trigger “when garage door opening” nothing happens when the door opens. Any thoughts.
    Couple of things to help me troubleshoot.
    1: Make sure the "Forum Name" setting in the plugin is set to "feobrien"
    2: Click the "Submit Debug Data" button in the settings, do this with the door open and the door closed.
    3: Let me know when this is done and I'll pull the report from the centralized error reporting system I setup and see if I can spot the problem.
