INFO: Plugin start is pending
  • INFO: Plugin start is pending
    I installed the MyQ plugin and when I start it I get the following: INFO: Plugin start is pending
    Any ideas? I tried uninstalling and reinstalling.
    Try disabling the plugin from the PLUG-INS > Manage tabs. Then go into PLUG-INS > MYQ Configuration. Verify your login information is correct. At one point I had to put incorrect login info, SAVE and then go back and enter correct login credentials and SAVE. Then go back and re-enable the plugin. The Plug in not starting up can sometimes be incorrect login details to your MYQ account. This worked for me.
      Sometimes this is just a visual bug with HomeSeer and the plugin is actually running. To find out if it's actually running you should see a new configuration page under the plugins menu called "MyQ" if you see this, it's actually running and the status is just bugged in HomeSeer.
