Change on to open and off to close.
  • Change on to open and off to close.
    Hi, can you change the Alexa voice commands from on to open and off to close?
    You could create Alexa routines with your preferred voice command. Wording can be (almost) anything you'd like. Have the Alexa routine trigger the on or off command as appropriate. You'll need separate routines for open and close.
    -Wade
      Is this done thru the Alexa app or thru HS?
        Alexa app.
        -Wade
          Ok thanks... I'm working on it now.
            It works fine thanks!...Just curious is that the only way to accomplish this? You can't change it in HS ?
