MyQ Garage Door won't open on version 1.2019.1110.1793
This topic is closed.
  • #16
    Disregard - I found an outdated Newtonsoft.Json.dll in the HomeSeer directory (I updated the dll & rebooted) Everything is running.
    • #17
      I've updated to 1703 on HS3 Pro for Linux and the plugin refuses to start and hangs in "Initializing" mode.
      • #18
        The latest version is 1793, please update to that latest version.
        • #19
          Sorry it is 1793 ... the "0" was a typo...
          • #20
            Ok, What version of Mono are you running? I'll setup a duplicate here and see if I can recreate your issue. Have you tried removing the plugin and reinstalling it?
            • #21
              Mono is 5.4.1.7 ... I have tried removing and reinstalling and multiple reboots
              • #22
                Ok, sorry for the problems, I'll get a linux machine up tonight with your parameters and see if I can recreate the issue.
                • #23
                  Are you getting a JSON error in your log? After upgrading to 1793 my SEL would hang on "Initializing". Discovered an old Newtonsoft.Json.dll in the HomeSeer directory - replaced the Newtonsoft.Json.dll with a more current version, rebooted and all is well. Not sure where the old Newtonsoft.Json.dll came from.
                  • #24
                    That's a great point!
                    E.S.Buckey, if you delete the plugin, homeseer just removes the .EXE file and not the .DLL files. Try this.
                    Remove plugin
                    Delete the contents of the folder homeseer/bin/MyQ/
                    Reinstall plugin
                    • #25
                      Do you have that version of Mono locked in for other plugins, purposes? I'm running Ubuntu Server with Mono 6.4.0.198 and haven't had so much as a blip in last 3 versions. Previous 2 versions I manually updated but updated 1793 through updater. May not want to do it as I've read somewhere that Mono 6 has issues with HttpClient and may jack up some configurations that rely on it but I haven't seen it <yet>. Just throwing it out there.
                      • #26
                        Remove plugin
                        Reinstall plugin
                        May be why I haven't had any problems. When I manually update I delete every trace of a plugin before I copy new files over.
                        • #27
                          So one suggestion is update Mono. But first I'll do the manual removal of the plugin folder and DLLs. I'll report back.
                          • #28
                            Here, try this... I just posted version 1.2019.1113.1516 in the beta section of the plugin manager. There's no differences except it deletes the old DLL files before installing the new ones. Give that a try and let me know.
                            • #29
                              Has anyone heard back from kingfetty about this issue yet?
                              Plugin's:
                              • #30
                                having same issue. just loses connection/status after some time. rebooting the PI solves it.
