MyQ been broken since mid-november, spins on "Still Initializing" - Fixed!
This topic is closed.
  • #76
    Ugh...looks like I got blacklisted. My MyQ app no longer works while on my home network and the plugin has been down for weeks. I am going to disable the plugin until the new fix comes out. How long are does it take to get off the blacklist?
    • #77
      The blacklist comes off fairly quickly (if it's still an issue in a couple of days I think there is something else wrong). That said, are you using the beta version of the plugin? I have had no issues since I installed the latest beta.
      • #78
        I am still running the prod version. I'll wait to get off the list and try the Beta.
        • #79
          I downloaded the latest beta release for MyQ and I noticed the drop-down for logging. Initially, logging was set to Debug so I changed it to Error and then noticed a message on the configuration screen that logging was set to Trace and not to leave it that way for extended periods. I reset it to Error but had to restart the system, when it came back up it was set to MyQ logging was set to Trace again and I had a log full of messages. Once I set it to Error the log messages quit but any idea why it won't stay to what ever was selected prior to restart?
          • #80
            Eric mentioned in an earlier post that the Beta versions would be forced to more detailed logging, to make troubleshooting easier. The production version will allow you to set it how you would like.
            • #81
              Hey all,
              Just got back home about an hour ago. I've submitted the latest version to Homeseer for production release. Not sure when they'll publish it due to the holidays and the weekend.
              For those running the beta version, the beta is LOCKED to debug logging level on purpose. Once you install the production build the normal logging level will return.
              • #82
                The MyQ plugin on my HS3Pro also stopped working in November, and I haven't been able to determine what happened. An update was published, I downloaded to install like usual with updates, the install for the plugin failed, and disappeared from the list of plugins in HS3 Pro - gone. Additionally, when I reboot / restart Homeseer, I get an error in the startup log showing that it is looking for the plugin but can't find it. Eventually startup skips it and everything else in my system works fine, but I can't seem to fix the MyQ - and I don't see a way to delete the plugin to at least eliminate the startup error as it appears to be gone already, and I also don't see a way to reinstall the plugin without paying $39.95 again. Any advice? The plugin has worked very well, and I would like to keep it!
                Notes: MyQ and garage door working fine, MyQ iPhone app controlling the garage door working properly, Homeseer otherwise working properly.
                Starting up....
                12/27/2019 9:03:58 PM ~!~Error~!~Warning, Cannot load EXE file (possibly missing dependencies) HSPI_MyQ.exe: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.Warning, Error details with EXE HSPI_MyQ.exe: Could not load file or assembly 'SendGrid, Version=9.12.0.0, Culture=neutral, PublicKeyToken=4f047e93159395ca' or one of its dependencies. The system cannot find the file specified.
                12/27/2019 9:03:59 PM ~!~Starting Plug-In~!~Initializing plugin Z-Wave ...
                12/27/2019 9:04:01 PM ~!~Starting Plug-In~!~Plugin Z-Wave started successfully in 1875 milliseconds
                12/27/2019 9:04:01 PM ~!~Starting Plug-In~!~Z-Wave loaded in 2347 milliseconds
                Startup Complete, 1 errors detected, check the log for more information.
                log detail
                12/27/2019 9:03:55 PM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer LOG database C:\Program Files (x86)\HomeSeer HS3\Logs\HomeSeerLog.hsd
                12/27/2019 9:03:55 PM ~!~Startup~!~Loading Settings
                12/27/2019 9:03:55 PM ~!~Startup~!~Settings Loaded.
                12/27/2019 9:03:55 PM ~!~Startup~!~*********************************************** *********************************
                12/27/2019 9:03:55 PM ~!~Startup~!~ HomeSeer version 3.0.0.548 Edition: HS3 Pro Starting Now
                12/27/2019 9:03:55 PM ~!~Startup~!~Creating Class Objects...
                12/27/2019 9:03:55 PM ~!~Startup~!~COM port classes started.
                12/27/2019 9:03:55 PM ~!~Startup~!~Application interface class started.
                12/27/2019 9:03:55 PM ~!~Startup~!~Web server class started.
                12/27/2019 9:03:55 PM ~!~Startup~!~E-Mail SEND class started.
                12/27/2019 9:03:55 PM ~!~Startup~!~E-Mail RECEIVE class started.
                12/27/2019 9:03:55 PM ~!~Startup~!~Plug-In Interface class started.
                12/27/2019 9:03:55 PM ~!~Startup~!~Local voice recognition class started.
                12/27/2019 9:03:55 PM ~!~Startup~!~Database SAVE process started.
                12/27/2019 9:03:55 PM ~!~Startup~!~Loading configuration file ...
                12/27/2019 9:03:55 PM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\101Woodland.hsd
                12/27/2019 9:03:56 PM ~!~Database~!~Loading Devices...
                12/27/2019 9:03:56 PM ~!~Load Config~!~480 total devices loaded.
                12/27/2019 9:03:56 PM ~!~Load Config~!~Loading Event Groups...
                12/27/2019 9:03:56 PM ~!~Load Config~!~Loading Events...
                12/27/2019 9:03:56 PM ~!~Load Config~!~31 total events loaded.
                12/27/2019 9:03:56 PM ~!~Load Config~!~Loading COUNTERS...
                12/27/2019 9:03:56 PM ~!~Load Config~!~Loading TIMERS...
                12/27/2019 9:03:56 PM ~!~Startup~!~HomeSeer version is: 3.0.0.548
                12/27/2019 9:03:56 PM ~!~Startup~!~Creating Speaker Client Interface Object...
                12/27/2019 9:03:56 PM ~!~Startup~!~This version of HomeSeer is registered as a HS3PRO version.
                12/27/2019 9:03:56 PM ~!~Web Server~!~Local IP address (subnet) is: 192.168.1.213 (255.255.255.0)
                12/27/2019 9:03:56 PM ~!~Web Server~!~Web Server started on port 80
                12/27/2019 9:03:56 PM ~!~Startup~!~Creating ASP.NET application host...
                12/27/2019 9:03:57 PM ~!~Info~!~Remote plug-in API interface started on port 10400
                12/27/2019 9:03:57 PM ~!~Startup~!~Checking for available plug-ins
                12/27/2019 9:03:58 PM ~!~Plug-In~!~Found plug-in: Sonos, version: 3.1.0.51
                12/27/2019 9:03:58 PM ~!~Plug-In~!~Found plug-in: Z-Wave, version: 3.0.2.0
                12/27/2019 9:03:58 PM ~!~Startup~!~Initializing Plug-Ins
                HomeSeer Version: HS3 Pro Edition 3.0.0.548 (Windows)
                HomeSeer: Is Registered
                OS Version: 10.0.18363 Service Pack: 0.0
                • #83
                  JSTA
                  I sent a new update in for them to publish and should be on the updater some time monday I'm guessing. In the meantime, it looks like some of the dependencies didn't get installed when you installed the update. Try deleting the DLL files under C:\Program Files (x86)\HomeSeer HS3\bin\MyQ\ and the HSPI_MyQ.exe file under C:\Program Files (x86)\HomeSeer HS3\
                  Once those are all gone, the plugin is essentially removed and then you can try the new install on monday, if you still have issues after the new update, let me know and I'll work with you to get it up and running.
                  • #84
                    OK - Thank you. I'll look for the new update this week, and will let you know what happens when I install.
                    • #85
                      The title says fixed, but I just installed the latest beta and it’s still not fixed for me.
                      I removed the DLLs, reinstalled the beta, and same problems. I don’t believe I’m blacklisted as every other method of using MyQ, including the iOS app and HomeKit on the same network, works fine.
                      Given I’m the OP, would you mind changing the subject back to “not fixed”? Apparently I can’t change this myself.
                      Mark
                      • #86
                        AbMagFAb
                        It sounds like you're having a different issue than everyone else. Since this thread is muddled enough, I'll close the thread, can you please start a new thread or message me directly with your current situation so I can focus on your specific issue. The blacklisting has been solved with the latest release available today.
