netstandard error after upgrading to 1.2020.131.1794
  • kingfetty
    ok, version 1.2020.0214.1496 has been published for homeseer to add to the updater. Only change is that it includes the netstandard.dll file.
  • chuckk9032
    Originally posted by kingfetty View Post
    Well, here's a list of all the possible DLLs that it may ask for. Start with the netstandard.dll and place it in the Homeseer\bin\MyQ folder. Then try to launch the plugin again, if it complains about another missing dll, grab it from the zip file and repeat. Make not of each missing one on the 2016 server and let me know. Then I can include them in the installer.
    https://kingfetty.blob.core.windows.net/files/DLL.zip
    netstandard.dll did the trick.
    Let me know if you'd like a list of the DLLs that are in the directory now.
    Thanks as always.
  • kingfetty
    Originally posted by chuckk9032 View Post
    I have the same issue on a Win 2016 server. I haven't patched the DLLs so let me know what I can do to help.
  • chuckk9032
  • kingfetty
    So, I may need your assistance tracking this down after all. If I do a blank server 2016 install, and just install the current version of Homeseer 3, the plugin is able to download and launch just fine without any added DLL files. So there's something specific about your installation that is requiring the extra DLL files.
  • kingfetty
    Let me finish testing with the new VM I built, don't want to make you go out of your way. I'm just glad you're back up and running now.
  • David D
    I just put them all in but I can go back and take them out to figure out which one if you need me to.
  • kingfetty
    Which DLL fixed it, or did you just throw em all in there?
  • David D
    Seems like the DLL files fixed the problem. No errors now and all the doors showed back up.
  • kingfetty
    4.6.2 is the required framework for the plugin. I'm booting up a new server 2016 VM fresh install to test with and see what's going on.
    In the meantime, here's a zip file of all possible DLL files that it could ever complain about. If it says it's missing one, you can unzip the DLL into the "HomeSeer\bin\MyQ" sub directory. If you do find it complains about things other than netstandard.dll, let me know and I'll be sure to package them into the next release.
  • David D
    4.6.2
  • kingfetty
    Ok, that's one OS I did not test on. What version of .Net Framework is installed?
  • David D
    Windows server 2016 Virtual Machine
  • kingfetty
    That appears to be the correct config file. What operating system are you on? Windows or Linux? I tested on many versions of both before releasing, just trying to find the difference. In the meantime, I'll zip up all possible DLLs that could be missing and package them up into the next BETA build so that you can install the beta to get up and running before a release can be published.
  • David D
    <?xml version="1.0" encoding="utf-8"?>
    <configuration>
    <configSections>
    </configSections>
    <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
    <probing privatePath="Bin\MyQ" />
    <dependentAssembly>
    <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" />
    <bindingRedirect oldVersion="0.0.0.0-12.0.0.0" newVersion="12.0.0.0" />
    </dependentAssembly>
    <dependentAssembly>
    <assemblyIdentity name="NLog" publicKeyToken="5120e14c03d0593c" culture="neutral" />
    <bindingRedirect oldVersion="0.0.0.0-4.0.0.0" newVersion="4.0.0.0" />
    <dependentAssembly>
    <assemblyIdentity name="System.Numerics.Vectors" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
    <bindingRedirect oldVersion="0.0.0.0-4.1.4.0" newVersion="4.1.4.0" />
    <dependentAssembly>
    <assemblyIdentity name="System.Runtime.CompilerServices.Unsafe" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
    <bindingRedirect oldVersion="0.0.0.0-4.0.6.0" newVersion="4.0.6.0" />
    <dependentAssembly>
    <assemblyIdentity name="System.Buffers" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
    <bindingRedirect oldVersion="0.0.0.0-4.0.3.0" newVersion="4.0.3.0" />
    <dependentAssembly>
    <assemblyIdentity name="System.ValueTuple" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
    <dependentAssembly>
    <assemblyIdentity name="System.Threading.Tasks.Extensions" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
    <bindingRedirect oldVersion="0.0.0.0-4.2.0.1" newVersion="4.2.0.1" />
    </assemblyBinding>
    <probing privatePath="bin/MyQ" />
    </assemblyBinding>
    </runtime>
    <startup>
    <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.6.1" />
    </startup>
    </configuration>
