Homeseer working fine but not showing up in Alexa
  • Homeseer working fine but not showing up in Alexa
    Got the garage door setup in HomeSeer and i can open iand close it fine. When i try to add as a Homeseer Skill in Alexa it is not found. Other devices in Homeseer are found in Alexa, just not the Garage door. Please help
    I'm not sure how to help with that, any integration with Alexa is handled by homeseer, not the plugin. The only thing that's required for the device to show up in homeseer is for the device status have the "Control Use" set to a supported Alexa setting, which the default value is ON for Open and OFF for Closed and this is supported by Alexa. If you've changed this, that may explain your issues.
      Thanks for the reply. I did not change any settings from base install. This is what I see
        Enable Voice Command (checkbox) on the device configuration screen. Yours is disabled. Then use Alexa to rediscover...
          Thank you Kevins669! That was it!
            Glad to help. You can also change the Voice Command name or create virtual devices with custom voice commands to say "open" or "close" the garage door/gate/etc. That is what I did to get around telling her to "Turn On the Driveway Gate".
              Kevin, very new to this, which settings should I change to Open and Close, or how would I create a virtual device?
                smcneill have a look at this thread. It should explain how to create and modify virtual devices: https://forums.homeseer.com/forum/ho...d-modification
                  Thanks Ando!
