Login attempts have repeatedly failed.
    Hello All,
    Let me start off with everything that was working, HS3, MyQ plugin, and my phone app.
    My Android Phone Application did an update which cleared my previous login credentials and required a fresh login. This is where my trouble starts.
    I tried to reset my update my password on the application.
    Well, the password reset link on the application did not work, and there is no password reset on the MyQ Website.
    I sent an email to MyQ support, several days later they respond, please delete your app and reinstall the app from the Play Store. Ok great, now the reset link works and I am able to create the password reset request.
    Now my Application works, now to update my MyQ Plugin. One thing I noticed is now my Application has ads, yikes.
    This is from my log file:
    Feb-08 7:39:38 AM MyQ Configuration Page Loaded, Page:MyQ
    Feb-08 7:39:33 AM MyQ Login attempts have repeatedly failed. Check Username/Password or select a different API type.
    Feb-08 7:39:29 AM MyQ Login attempts have repeatedly failed. Check Username/Password or select a different API type.
    Feb-08 7:39:25 AM MyQ Login attempts have repeatedly failed. Check Username/Password or select a different API type.
    Feb-08 7:39:21 AM MyQ Login attempts have repeatedly failed. Check Username/Password or select a different API type.
    Feb-08 7:39:17 AM MyQ Login attempts have repeatedly failed. Check Username/Password or select a different API type.
    Feb-08 7:39:13 AM MyQ Login attempts have repeatedly failed. Check Username/Password or select a different API type.
    Feb-08 7:39:13 AM MyQ Response Code: Unauthorized
    Feb-08 7:39:13 AM MyQ Sent authentication post to MyQ server
    Feb-08 7:39:13 AM MyQ HTTPResponseCode Unauthorized, HTTPResponseContent: {"code":"401.207","message":"Unauthorized","description": "Th e user is locked out."}
    Feb-08 7:39:12 AM MyQ Created credentials JSON data
    Feb-08 7:39:12 AM MyQ LiftMaster: Login Attempt
    Feb-08 7:39:12 AM MyQ Response Code: Unauthorized
    Feb-08 7:39:12 AM MyQ Sent authentication post to MyQ server
    Feb-08 7:39:12 AM MyQ HTTPResponseCode Unauthorized, HTTPResponseContent: {"code":"401.207","message":"Unauthorized","description": "Th e user is locked out."}
    Feb-08 7:39:11 AM MyQ Created credentials JSON data
    Feb-08 7:39:11 AM MyQ LiftMaster: Login Attempt
    Feb-08 7:39:11 AM MyQ Response Code: Unauthorized
    Feb-08 7:39:11 AM MyQ Sent authentication post to MyQ server
    Feb-08 7:39:11 AM MyQ HTTPResponseCode Unauthorized, HTTPResponseContent: {"code":"401.207","message":"Unauthorized","description": "Th e user is locked out."}
    Feb-08 7:39:08 AM MyQ Created credentials JSON data
    Feb-08 7:39:08 AM MyQ LiftMaster: Login Attempt
    Feb-08 7:39:08 AM MyQ Session invalid, calling authentication attempt
    Feb-08 7:39:08 AM MyQ AccountURL is null, have not authenticated yet
    Feb-08 7:39:08 AM MyQ Poller interval normalized to 10000
    Feb-08 7:39:08 AM MyQ Pausing PollTimer while updating device status
    Feb-08 7:38:58 AM MyQ Registered for device change events
    Feb-08 7:38:58 AM MyQ Started PollTimer
    Feb-08 7:38:58 AM MyQ Created HTTP client. AppID:CUvB6irHOoph0WcjYn5f0cdG3XUiJcN646iw4v3QHXQaM5A8G4YipZ a3LfOvz7Ya
    Feb-08 7:38:58 AM MyQ PolicedHttpClient finished initialization.
    Feb-08 7:38:58 AM MyQ Initialize MyQ Controller. API: LiftMaster, User:xxxxxxx@cox.net, Pass:xxxxxxxx, Interval:10000
    Feb-08 7:38:57 AM MyQ Initializing MyQ Controller
    Feb-08 7:38:53 AM Plug-In Finished initializing plug-in MyQ
    Feb-08 7:38:53 AM Starting Plug-In MyQ loaded in 5174 milliseconds
    Feb-08 7:38:53 AM Starting Plug-In Plugin MyQ started successfully in 503 milliseconds
    Feb-08 7:38:53 AM MyQ Completed registering configuration page
    Feb-08 7:38:53 AM MyQ Registered configuration link menu item
    Feb-08 7:38:53 AM MyQ Set configruation page url to MyQ
    Feb-08 7:38:53 AM MyQ Registered single instance configuration page
    Feb-08 7:38:53 AM MyQ Creating configuration web page
    Feb-08 7:38:53 AM MyQ Enabled logging to HomeSeer log system
    Feb-08 7:38:53 AM MyQ Initializing version 1.2020.705.1301
    Feb-08 7:38:52 AM Starting Plug-In Initializing plugin MyQ ...
    Feb-08 7:38:52 AM Info Plugin MyQ has connected. IP:127.0.0.1:55542
    Feb-08 7:38:41 AM Info Plugin MyQ with instance: has disconnected
    Feb-08 7:38:41 AM MyQ Stopped Controller
    Feb-08 7:38:41 AM MyQ LiftMaster: Stopping MyQ Controller
    Feb-08 7:38:41 AM MyQ HomeSeer shutting down MyQ plugin
    Feb-08 7:38:41 AM Plug-In Shutting down Plug-In: MyQ
    Feb-08 7:38:16 AM MyQ Changing Logging Level to: Debug
    Anyone here experienced the same situation?
    Denny
    Printers and passwords. The two things most responsible for slowing me down in life. And printers have gotten a little better lately. Passwords? Not so much. Every day it seems some website or other has decided that my password "just isn't good enough." So I go to change it, and invariably it no longer recognizes my old one, or the change doesn't take, and I'm stuck in the Twilight Zone...or SOMETHING.
    I feel your pain. Wish I could help. I have MyQ, but mine's working like a charm, and so I've never bothered with learning about it.
    Jim Speiser
    Still don't know squat
