Version 3.0.2.1 - What's the change?
  • Version 3.0.2.1 - What's the change?
    Anyone know what the newest update changes? The release notes link in the updater doesn't point to release notes, just back to the plugins page.
    I need to update the sticky post. You can find a link to the README from the sticky post that points to http://www.kazteel.com/HomeSeer3/Nap...NI_README.html
    The note from the README for 3.0.2.1 reads:
    Version 3.0.2.1 (11/17/2017)
    Do not update timestamp on HS3 device for every area status update from the keypad bus
    This was a minor update to prevent updating the area device "last updated timestamp" just because we saved the ICON, LED, and Line1/2 info into the virtual device based on the constant keypad bus updates. If I recall, someone asked for that so the area device didn't keep looking like it was being updated just because of traffic on the keypad bus.
    Also note, HST is changing how plugin authors provide changes to the updater and they are working on at least one bug related to the "Release Info" link isn't correctly showing. That might have helped you track down this link to the README but now you have it. Hope this helps.
    Nathan
    HS 3.0.0.435 (PRO)
    Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
    Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
    Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
      Perfect. Thanks for the quick response and Rock solid plug-in.
      Sent from my Pixel 2 using Tapatalk
