Convert to stay
  • humphreysr
    that fixed it - Thanks
  • nfrobertson
    I just released v3.0.0.3 You discovered a small but significant bug with the triggering of events from the second larger list. Please upgrade to this new version and see if your problem is fixed.
  • humphreysr
    I am trying to trigger an event off:
    Napco Gemini : Convert to Stay for [Area 1] for Zone [Any Zone]
    I want to know when the alarm is armed but in Stay mode. I put it in stay mode by pressing and holding the "stay" button for 5 secs.
    in the debug log I see that the following is recorded:
    5/8/2014 7:41:33 PM ~ Napco Gemini ~ DEBUG ~ EXIT TIME 010
    5/8/2014 7:41:33 PM ~ Napco Gemini ~ DEBUG ~ PLEASE LEAVE NOW
    5/8/2014 7:41:33 PM ~ Napco Gemini ~ DEBUG ~ --------------------------
    5/8/2014 7:41:42 PM ~ Napco Gemini ~ INCOMING ~ Status event received: EC, 0, 0: Convert to Stay
    5/8/2014 7:41:42 PM ~ Napco Gemini ~ TEST ~ TRIGGER REQUEST received: EC, 0, 0: Convert to Stay
    5/8/2014 7:41:42 PM ~ Napco Gemini ~ TEST ~ No triggers matched!
    5/8/2014 7:41:43 PM ~ Napco Gemini ~ DEBUG ~ Panel Area 1 Panel Armed? True
    5/8/2014 7:41:43 PM ~ Napco Gemini ~ DEBUG ~ Led1 = /images/NAPCO_GEMINI/red_led.gif, Led2 = , Icon1 = BYPASS, Icon2 =
    5/8/2014 7:41:43 PM ~ Napco Gemini ~ DEBUG ~ --------------------------
    5/8/2014 7:41:43 PM ~ Napco Gemini ~ DEBUG ~ ARMED STAY
    5/8/2014 7:41:43 PM ~ Napco Gemini ~ DEBUG ~ 05/08/14 07:39PM
    I am using a P3200 Panel with GEM-K1CA keypads.
  • nfrobertson
    Do you have debugging turned on in the plugin? If so, you should have a file in HomeSeer HS3\Logs\NapcoGeminiDebug.log Can you look at that and see if there are any relevant lines you want to post to the forum. Please note that the master code may be displayed in that log. I will remove that in a future release. You'll want to be sure not to paste that here.
    There are many events that the panel can generate. If you then setup an HS3 event with the corresponding trigger it should work. I'm using this for the most common ones like zones opened, alarm triggered etc.
    Can you detail the steps you perform with the panel/keypad to get the desired event in the log that doesn't seem to be working? I'd like to try and reproduce with my panel.
    What panel are you using?
    I will see about hooking my panel to the dev machine this weekend and testing this. Any additional details you can provide will be helpful. Thanks.
  • humphreysr
    started a topic Convert to stay
    Convert to stay
    I just started using the plugin today. (finally upgraded to HS3)
    I wanted to trigger an event when the system was in Stay mode. I see in the log "Status event received: EC, 0, 0: Convert to Stay" but the trigger in the event does not seem to work. any idea?
