Napco Plug-in choking on Carbon Monoxide Detector
  • Napco Plug-in choking on Carbon Monoxide Detector
    Plugin Version=3.0.0.5
    I have a Gemini 3200 with a very new EEPROM; it is the EEPROM that works with the Napco iBridge ethernet / zwave unit.
    Communication seems OK up until my 13th zone which is one of my Carbon Monoxide detectors:
    Specifically:
    Full Log:
    So based on your log, it appears that newer EEPROM on P3200 panels that are iBridge compatible may work with this plugin, at least in some capacity. I have to assume that much of the protocol implemented by the GEM-AUTOMATION EEPROM must be built into this version of the EEPROM - only a guess however.
    Is the CO detector you mention the FW-CO1224 like found at the link below?
    http://www.napcosecurity.com/images/...wolfCOspec.pdf
    HS 3.0.0.435 (PRO)
    Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
    Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
    Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
    http://www.kazteel.com/
      Hi,
      No actually they are Macurco CMS1's.
      http://homeappliance.manualsonline.c...urco/cms1.html
      I'm guessing maybe since these are not NAPCO products (though they are intended to be hardwired into a control panel) they might not respond to the:
      CMD_ZONE_DESC_LOW command?
        The Napco GEM-AUTOMATION EEPROM is what this plugin was developed to operate with. It is an HS3 port with some improvements over the original Napco plugin for HS2. I can't really comment on non-Napco devices and how the GEM-AUTOMATION or the apparently newer iBridge compatible EEPROM will respond with a non-Napco device. When I have some time to look further at this I may consider getting one of the Napco CO detectors and see if it works or has issues like you are seeing.
        HS 3.0.0.435 (PRO)
