The original versions of HS supported VBScript and then VB.NET so most scripts have been developed with that. Consequently few people use C# so there's a good chance you'll find some bugs as you may be the the first one trying something . I recall seeing some posts a few months ago where someone had figured out how to pass the parameters to a C# script. I'll see if I can find that threat. I don't think I was able to use quotation marks to pass parameters to vb.net scripts either, but it definitely does not cause HS to crash if you do.
Cheers
Al
Cheers
Al
