Omni connection issue
  • Omni connection issue
    Hi
    I am having trouble connecting to my leviton omni lte panel,The encryption keys IP address and port are all correct however within the Omni log it seems it connects to the omni then immediately disconnects. Bellow is the Omni log file, your help would be much appreciated
    10/21/2017 8:20:51 PM [1] [-->Reading configuration...]
    10/21/2017 8:20:48 PM [2] [CONNECTION STATUS: Disconnected]
    10/21/2017 8:20:48 PM [2] [Identifying Controller...]
    10/21/2017 8:20:48 PM [2] [Panel Connected.]
    10/21/2017 8:20:48 PM [2] [CONNECTION STATUS: Connecting]
    10/21/2017 8:20:48 PM [2] [Connecting with: [192.168.0.101] [4369] [TCP]]
    10/21/2017 8:20:48 PM [2] [HAC Connection state is: Offline]
    10/21/2017 8:20:48 PM [2] [Device initialization is complete.]
    10/21/2017 8:20:46 PM [2] [Initializing Timers...]
    10/21/2017 8:20:45 PM [2] [OMNI Plugin Thread was started.]
    10/21/2017 8:13:02 PM [1] [-->Reading configuration...]
    10/21/2017 8:12:59 PM [2] [CONNECTION STATUS: Disconnected]
    10/21/2017 8:12:59 PM [2] [Identifying Controller...]
    10/21/2017 8:12:59 PM [2] [Panel Connected.]
    10/21/2017 8:12:59 PM [2] [CONNECTION STATUS: Connecting]
    10/21/2017 8:12:59 PM [2] [Connecting with: [192.168.0.101] [4369] [TCP]]
    10/21/2017 8:12:59 PM [2] [HAC Connection state is: Offline]
    10/21/2017 8:12:59 PM [2] [Device initialization is complete.]
    10/21/2017 8:12:57 PM [2] [Initializing Timers...]
    10/21/2017 8:12:56 PM [2] [OMNI Plugin Thread was started.]
    10/21/2017 8:06:55 PM [1] [-->Reading configuration...]
    10/21/2017 8:06:53 PM [2] [CONNECTION STATUS: Disconnected]
    10/21/2017 8:06:52 PM [2] [Identifying Controller...]
    10/21/2017 8:06:52 PM [2] [Panel Connected.]
    10/21/2017 8:06:52 PM [2] [CONNECTION STATUS: Connecting]
    10/21/2017 8:06:52 PM [2] [Connecting with: [192.168.0.101] [4369] [TCP]]
    10/21/2017 8:06:52 PM [2] [HAC Connection state is: Offline]
    10/21/2017 8:06:52 PM [2] [Device initialization is complete.]
    10/21/2017 8:06:50 PM [2] [Initializing Timers...]
    10/21/2017 8:06:49 PM [2] [OMNI Plugin Thread was started.]
    10/21/2017 8:03:16 PM [1] [-->Reading configuration...]
    10/21/2017 8:03:13 PM [2] [CONNECTION STATUS: Disconnected]
    10/21/2017 8:03:13 PM [2] [Identifying Controller...]
    10/21/2017 8:03:13 PM [2] [Panel Connected.]
    10/21/2017 8:03:13 PM [2] [CONNECTION STATUS: Connecting]
    10/21/2017 8:03:13 PM [2] [Connecting with: [192.168.0.101] [4369] [TCP]]
    10/21/2017 8:03:13 PM [2] [HAC Connection state is: Offline]
    10/21/2017 8:03:12 PM [2] [Device initialization is complete.]
    Current Date/Time: 10/22/2017 12:15:34 PM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.318
    Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 16 Hours 9 Minutes 15 Seconds
    IP Address: 192.168.0.22
    Number of Devices: 15
    Number of Events: 4
    Available Threads: 393
    Enabled Plug-Ins
    3.0.0.103: HSTouch Server
    3.0.2.4: OMNI
    3.0.1.83: Z-Wave
    A couple of things to check :
    Are you selecting the correct label type?
    Using pc access or your console, verify that the date /time are correct.
    Sent from my Galaxy S7 Edge using Tapatalk
      Have checked the time and date, it was out a minute or so time is now correct. not sure what you mean by the correct label type
        Sorry, meant panel type. Make sure it is set to your lte panel.
          the time still seems to be out 10 seconds or so but wouldnt have thought this would have been an issue
            No - a few/seconds/minutes wouldnt be an issue.
            There was an issue early-on when the clock was not set at all that caused the plugin to bomb.
            The logs seem to stop around the time it is trying to identify the controller (panel). On the config screen for the plugin, do you have the correct panel type selected? I see you are running an Omni lte - just make sure the dropdown has that panel type selected and let me know.
              Yep thats right
                Here is a few more pics
                  Ah - thanks for the screenshots - that helps...
                  Let me take a look at the API specs for the lte panel and see if I can spot anything. Sit tight until I report back...
                    Ok thanks, is it ok that i have posted my encryption keys? should i delete that one?
                      no
                      Yes.
                      or
                      crop the keys out using a photo editor.
                      Here do not have dashes or spaces between the keys...I do not know if that makes a difference.
                      I redid my keys here using dashes, disabled the plugin and re enabled the plugin and it connected fine.
                      [ATTACH]64042[/ATTACH]
                      - Pete
                      Auto mator
                      HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
                      HS4 Lite -
                        Tried it with upper case and lower case and still no joy
                          ok, it's definitely your panel type that is the problem. The logs show it identifying the controller, but it is not the correct type.
                          Are you sure it is an Omni LTe?
                          Can you try changing the dropdown to Omni LT and restart the plugin?
                          If those do not work, I need to release a build that will give me more info.
                            I have homeseer set to DHCP could this be an issue?
                              tried that and still no change
